Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > Soyland Industries
Soyland Industries Custom developed models & parts regarding 1/14 trucks & construction machines
Old 02-24-2016, 05:46 AM
Rimrock Rimrock is offline
Default Eagle/RC4WD 4200XL excavator - track motors upgrade kit
P/N 22002 Track motor upgrade kit
340 USD, + shipping 40 USD worldwide (cost does not include VAT, sales tax etc that may be added at arrival in your country)
Track motor upgrade kit for Eagle JD-1/4200XL excavator (‘RC4WD Earth Digger)
These upgrade track motors will give you considerable higher power & more suitable max RPM than the original track motors. Original track motors has often be experienced as underpowered and the spur gear transmissions is one of the weakest points. The upgrade kit has industrial planetary transmissions that will take considerable more ‘beating’ than original transmission.
NOTES:
1)
UPDATE 10 March 2018 : Kits now delivered with outer diameter of motors turned down to 34.7mm, for direct mounting on both version 1 & 2 of the 4200XL, that have some variation in the track motor bracket's bore
2) The motors are NOT prepared to run submerged in water. The motor covers will protect from light rain and splash of water, but water will get into the motor if submerged. If getting submerged by accident, stop running at once, take covers off in order to let the motors dry out.
Kit includes;
• Planetary brushed gearmotors, 540 size motors (5000 rpm), output ~45 rpm max (versus original gearmotors ~20 rpm)
• Cables and minor electrical parts (existing motor cables in the undercarriage will be too short for the new track motors)
• Instruction manual (English, electronic)
(• Compression springs can be delivered as an option if one got the older version of the 4200XL with no original springs. 20 USD for a kit incl brackets)
Advantages too available brushless track motors upgrade kit on the marked;
• Less complicated and time consuming installation. No need for separation of undercarriage and upper structure in order to replace centre electrical slip ring
• More stable running of the tracks at ‘low trottle’ and more control than the brushless gearmotors which are relative high geared (60 rpm).
• Reduced problems regarding the tracks start rolling during digging operation, as can be experienced with brushless motors which are dependend of well functioning electronic parking brakes in the ESC’s. Brushless motors do not have the internal resistance against rotating, as is the case with brushed motors.
• The original brushed motor ESC’ can be used, and not to be replaced as is case with the brushless motors kit.
Pictures:
http://www.rclastebilbutikk1.no/tilb...wd-graver.html
Old 02-24-2016, 06:46 AM
Dieselchopper's Avatar
Default Re: Eagle 4200XL excavator - new track motors
I would be interested in thread and more info. Thanks
Old 02-24-2016, 01:18 PM
Northern Farmer's Avatar
Sweet upgrade Rimrock. Do you have a before and after video of the modification ?
Old 02-24-2016, 04:43 PM
bigford's Avatar
bigford bigford is offline
looks good rimrock!! let me know when you tackle the china kat also
Old 02-25-2016, 09:14 AM
Thanks guys) I guess I will open a sales thread in near future here with some more info, I also have other stuff in the coming. Should have some videos, definitely. Will try making a couple of videos, at least the 'after videos' of this machine, that's with a local customers now.
The KAT excavator, yeah that's one of our other acquaintances from China, 'we love China' I've got one of them myself, in pieces..See that it also should be in need for compression springs on the idler wheels, at least. What about the original track gearmotors? They seamed stronger than the Eagle motors, but I havn't tested them in operation for real yet. Anyone got problem with them?
Old 02-25-2016, 09:36 AM
bigford's Avatar
one of the guys in my china kat thread blew up two sets
Old 02-26-2016, 11:39 PM
thebigo thebigo is offline
I think everyone with a xl4200 would benefit from the compression springs, I have broke a lot of track sections with the original on mine.
David
Old 02-27-2016, 03:43 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Hi Rimrock,
I also own a Buychina Kat as well, If you were to make idler wheel kit with Retrofitted compression springs and a set of upgraded track gear motors for the buychina, I've would be happy to buy a set of each off you.
I bought my Kat around Xmas 2014 and I still have not got it up and running yet, due to work and life getting in the way and my replacement slip ring getting
lost in the mail for 3 months.
Regards Cam.
Old 02-27-2016, 08:41 AM
Thumbs up Re: Eagle 4200XL excavator - new track motors
Originally Posted by Kingcam2 View Post
Hi Rimrock,
Regards Cam.
Hi Cam, I see now that also the KAT could need a upgrade set, I will look into and see what can be done
Oyvind
Old 02-27-2016, 09:10 AM
once you have sets available for the 4200 I will defiantly take one. Stock stuff is done and need to fix.
Old 03-17-2016, 04:49 PM
A video of one 4200 with the new track motor kit. It's running here up to about 2/3 of full speed. Possible limited speed, in % of full, can be set on most radios. Pretty good torque from those motors, one need a very strong grip to stall them by griping the tracks with one hand) Planning to have some new kits ready for sale in April,
https://youtu.be/60gSjtnwJog
Old 03-17-2016, 06:32 PM
That 4200 moves around with ease! Great job Rimrock
Old 04-24-2016, 10:48 AM
Definitely keep us posted. I'm in for the motor upgrade and new tensioner when available.
Old 04-26-2016, 06:52 AM
April is almost up where the kits at ? Just busting your balls how's the kit coming along ?
Old 04-26-2016, 04:35 PM
Hi all, busy days with different projects going on parallel here, but just working at finishing the first 5 track motor kits this week, ready for shipping next week) Also creating a installation guide that comes with the kits.
For ordering, just send me a PM, and we take it from there
Old 04-27-2016, 02:23 PM
Thumbs up Re: Eagle 4200XL excavator - track motors upgrade kit (updated 26'th April 2016)
PM sent
Old 04-27-2016, 05:04 PM
Default Re: Eagle 4200XL excavator - track motors upgrade kit (updated 26'th April 2016)
PM sent
Old 04-30-2016, 04:46 PM
Talking Re: Eagle 4200XL excavator - track motors upgrade kit (updated 26'th April 2016)
Woohoo can't wait to put my ho to work with these new stronger motors!
Old 05-07-2016, 09:46 PM
You get yours installed yet? mine are still a couple weeks out.
Old 05-07-2016, 11:44 PM
No not yet parcel is still in transit.
