#1841
Post a pic of the bed next to my d11
Thats cat# 458-9587 |
#1842
I didn't want to touch the bed and sure didn't want to pick the dozer up next to it!!!
![]() Light is casting a shadow onto both of them and the tank only has one coat on it but you can see the difference in old cat yellow (tank) and new cat yellow (dozer can)
#1843
#1844
That's not it, that # would be Martin Kampshoff's stamp. The # I refer to is the # stamped right on the pump just above S P, it's sometimes very faint to see. The # on both these pumps is 4002 which is 0,30ml/revolution
#1845
Here is a suggestion to improve flow to your dump cyls, use 4mm fittings on the valve to a tee block, then 2,5mm fittings from tee to cyls. The 4mm fittings on valve need to be filed down to screw into place, just leave enough flat spot to snug with a wrench.
#1846
Cat changed the old "Hi-Way Yellow" to the new present day gloss yellow between 1979-1984. Main reason for was the old yellow had a high lead content which is now banned. The old paint lasted longer because of the lead though. I have restored several old Cats from the 30's that still retained the gray or yellow paint. |
#1847
![]() ![]() First coat on the frame. Joe the number on pump is 4002. Now that I have everything apart I'm going to open things up a bit try and make bigger hose work and open up the fittings some. I'm feeding both those big cylinders with one valve and 4mm hose. Doesn't make much difference if I up the rpm on pump so I'm pretty sure it's a restriction issue with all the small fittings and hose. Thanks joe ![]()
#1848
Thats a few cans of yellow right there
#1849
What's the pressure set to? Higher pressure will dramatically increase flow... 250psi would be bout right.
#1850
Looking at the gauge now I think I was only running 100-125 psi, around 10 bar. So plenty of room to up the pressure,,,
#1851
![]() ![]() Swapping out one of the 4:1 planets for a 3:1, increasing speed some. Trying to get up to 30 mph (1:1 scale) speed. Forget if I ever greased the other two planet gears, well it's apart so might as well clean and regrease. So I should end up with tranny being 3:1,3:1,4:1 then diff being 3:1 gearing reduction.
#1852
![]() ![]() Here is the gearbox taken apart still have 5 of the 3:1 planer gears inside the ring gear yet , but you can see the size. Couple of you asked about gearbox, banebots is where I got it from , it is the p80 size
#1853
Well what can i say this post is amazing I have just read from beginning to end over the last few days.
Very high level of work and quality. You shouldbe proud of your work. ![]() ![]() many thanks for sharing this with us all. Regards Mark Over the Pond in the UK |
#1854
#1855
Hi Bigford
Will do. Thanks for the pointer. Regards Mark Over the pond in the UK |
#1856
do you use any drawing programs 2d or 3d or whatever for when your building your projects? or just by hand?
#1857
his plans,drawings and everything
http://www.ebay.com/itm/NORSCOT-CAT-...YAAOSwnbZYHlBw http://www.ebay.com/itm/Norscot-5521...gAAOSw8w1X2HMn |
#1858
Yup that pretty much is it, for the d11 and haul truck I did also purchase (off eBay) a shop manual. It shows some parts to get better idea of how they fit and work. My plans are just number jotted down on a notepad and some rudimentary hand sketches. But I have it all thought out in my head
#1859
That's a great idea I seen the model toy but the shop manual would be really helpful. Can't wait to see it once it's all together.
#1860
![]() ![]() ![]() All parts painted with exception of having to hand paint railings. I didn't want to take them off as I might not get them back on ![]() ![]() And haven't seen this for a while!! Cleaned off and now ready to build her back up!! I did order some bigger smc fittings and need to make a splitter but no big deal for that. I went right to the source, Smcpneumatics.com Is the site that manufactures all the push to connect fittings. Cheaper to order from them and quicker than waiting for some from overseas. The site has all of them but you may have to go to the online catalog and find the part reference number because the pictures don't always match the part. I'll try and post this in the reference section for others also. Along with banebots.com for planetary gearboxes.
Always wasting money, as the wife says. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Cooper; 11-16-2016 at 01:25 PM. |
