Old 02-17-2017, 01:36 PM
Stuart's Avatar
Stuart Stuart is offline
Stuart is on a distinguished road
Default Joskin KTP27/65 Tridem
My new project, twin steering axles, hydro-tridem suspension (if it works!):
First steering axle:
Mounted:
Started the 2nd steering axle today:
Cheers
Stu
Old 02-17-2017, 04:21 PM
kolpen kolpen is offline
kolpen is on a distinguished road
Default Re: Joskin KTP27/65 Tridem
You caught my attention!
Thanks for sharing ☺️
Old 02-17-2017, 04:23 PM
Off to a good start. It will be an awesome addition to your fleet.
Old 02-17-2017, 04:49 PM
bigdogrod bigdogrod is offline
bigdogrod is on a distinguished road
what tires are those?
Old 02-18-2017, 02:01 PM
Stuart's Avatar
Your welcome
Thanks Emil
Round ones made from rubber .... Found them on modelltruckforum.de
Finished the 2nd steering axle today:
Now to sort the steering, mechanical linkage or servo, can't decide, might try the linkage method first.
Then onto the hydro-tridem suspension, not sure how thats going to turn out...
Thanks for looking
Stu
Old 02-18-2017, 05:17 PM
kerst's Avatar
kerst kerst is offline
Looks great!
Kerst
Old 02-23-2017, 05:03 AM
Grainfarmer Grainfarmer is offline
Grainfarmer is on a distinguished road
Tres jolie remorque! Bien fait...
regards,
Frank
Old 02-24-2017, 01:43 PM
Stuart's Avatar
Originally Posted by kerst View Post
Looks great!
Kerst
Thank You
Merci Frank!
Today I started the drawbar:
Old 03-01-2017, 01:26 PM
Stuart's Avatar
Fitted the draw bar:
Then converted the 1/10 shocks into single acting cylinders for the hydro-suspension:
Filled them with oil to create a closed loop hydraulic system:
Thanks for looking
Stu
Old 03-01-2017, 01:43 PM
Lots of hi-tech on this trl build Stuart it's gonna be wondrous to see it in motion
Old 03-04-2017, 10:53 AM
Great job! How did you get the air bubbles out of the suspension system?
regards,
Frank
Old 03-04-2017, 11:34 AM
Stuart's Avatar
Thanks Joe, gone a bit adventurous on this one!
Thanks Frank,
I connected the 3 cyls with the hoses then turned them upside down without the pistons fitted.
Filled no.1 with oil and put the piston in, pushed gently until oil appeared in the bottom of no.2, filled no.2 with oil and fitted the piston but pushed it all the way in then did no.3.
That way when 1 cyl is fully closed the other 2 are fully extended, et voila!
It works a treat, there a little on the tight side, may need to take a tad out the piston groove to loosen it but I'll try it loaded first.
I worked out that with a 15Kg load the pressure in the cyls is around 9 bar, should be ok, I hope!
Having trouble with the steering geometry at the moment, I've got too much travel at the axle end and it reaches full lock too soon so need to tweak the angles a bit, will update once done.
Stu
Old 03-06-2017, 01:06 PM
Stuart's Avatar
Got the steering sorted then made some brass connecting rods:
couple of videos:
Test 1
Test 2
Cheers
Stu
Old 03-06-2017, 03:45 PM
Fantastic. Thank you so much for sharing all your progress!!
Old 03-06-2017, 05:55 PM
kerst's Avatar
beautiful!
Kerst
Old 03-08-2017, 10:46 PM
Well that steering linkage system is gonna be comprised if you travel in extreme terrain!
Old 03-09-2017, 08:14 AM
Bo Wallen's Avatar
Thumbs up Re: Joskin KTP27/65 Tridem
Great work. However the straight axle should change place with the first steering axle. Otherwise the trailer try to go inside of the tractor and make two radius. Just my 2 cent.
Old 03-09-2017, 09:48 AM
porky69 porky69 is offline
porky69 is on a distinguished road
With 1st and 3rd axles steering they counter each other(front turns left rear turns right and vice versa) and allow for sharper turns without skidding the tires (should only leave one tire track that is undisturbed on each side).
Old 03-09-2017, 03:32 PM
Bo Wallen's Avatar
That would work if the trailer/Wagon wasn't hooked to a tractor with a drawbar.
That changes the pivot point from the center of wagon to somewhere else depending on length of drawbar e.t.c. Look at the video and pic.
Old 03-10-2017, 08:54 AM
I just watched a couple of videos on http://www.joskin.com/?page=transpor...7&user_lang=en and from what I saw it(the 1:1 version of what this one is modelled off of) works pretty much exactly like I described so I don't see why with a little fine tuning on linkages that the model would be any different.
