#2041
#2042
#2043
I see it now. I looked quickly not noticing I was looking at the bottom of your jig
![]() When you go to steel; Are you going to make a pin and bushing like Stevie did on his tracks? |
#2044
![]() ![]() ![]() I was worried about not having any negative arc and having to cut reliefs in each pad. But there is plenty, although the two reliefs would only help in partical release. Steve, I am just using a 3/16" rod cut down to 1/8" on each end for the pins. Made out of brass just like first time I did them. They have lasted awhile but I still would like to make a set in steel. I am thinking I'm going to just do them the same way. Steves bushings are better but a bit more work. Although I could still do something similar. The way I have the pins , once the links are bolted to pads is when the links are secured and can roll or grind ![]()
#2045
I know it's not any particular part but I just wanted to make something with some complex curves to see how the 3D machineing would work. All the ball endmills I have are well abused to it could have been a little better. Maybe this will help anyone thinking about one of these machines , and how easy it is. ,,, again I never had any experience with cam or cnc machines so if I can do it anyone can
![]() ![]() ![]() ![]() Just a quick rub with some scotchbrite ![]()
#2046
The machineing took just a little over 2 hours. Had a step over of .005 for final pass. It's pretty smooth but some visible paths are there. Some fine sanding would eliminate them. I did give it a quick polish with dremel, spent a whole 5 min!!
#2047
What's the nipple for and why is there only one?
Looking sweet! Keep it up! My wife says I can buy one but she thinks I should learn how to draw first. I have been working with my etch a sketch ever since! ![]() |
#2048
Hey reg, the best thing about this is I can't draw either!! The computer can!! Only problem with that , I don't communicate with computer very well!!!! When I want to make a simple square the darn computer asks too many questions,, like, where? What plane? What shape, size? How thick ,,, alot like a first date!!! Way too much questions and not enough actions!! But eventually I'm learning to speak computeries , very similar to my chinglish voculabarly. I've traded in my usual torture tools (hammer and torch) for more appropriate computers, now I threaten it with a magnet!!! So far the hard part of this has morphed into part holding. For the track links it made sense to cut soft jaws because of so many parts to be made. On some other one off parts the challenge has become how to design and make it with having to hold and machine it in mind. From my university of YouTube degree in cnc machineing a few guys had said that designers should spend time in the machine shop to get a better understanding of what available machines the company has can do. And the process involved. Really helps knowing what you can do and can't do. Like if I don't have a 1/2" drill then I better not make any holes 1/2" while designing my part. ,,,,, but I'm also learning from a lot of knowledgable people to think outside the box,,, like no 1/2" drills, no problem, use a 1/4" mill and extrapolate out to 1/2".
#2049
![]() ![]() ![]() ![]() And also chipping away at the fleet expansion project. Some pics of the camber I'm incorporating into the beams of trailers.
#2050
Looking good DB I 'll have to come down to your place so you can teach my. Ed
#2051
I like the bent beam ok sorry camber
#2052
Forgot I had a two piece vise, coming in handy now. I made two end pieces for the frame rails to nest in. Clamp them together and holds everything vertical and in dimensional shape for welding.
![]() ![]() The piece of alum in front is the first jig holder I made, it was too tight and needed a relief radius for the bend of ibeams. A little humor on that side project, first ones took me about 4 hours to figure out the cam for the cnc mill, the second set took about three min!!! One nice thing about fusion 360 is they give a brief description of what task at hand will do. Nice but if you don't know what any of it means then it's basically keep hitting buttons and operations until I find one that does what I want. That's why the 4 hours vs 4 min!!
#2053
#2054
Last week
![]() This week ![]() ![]() And some more on the trailer , close on the chamfer mill while machineing the support arms ![]() ![]()
#2055
And starting to understand the benefits of the printer, can make parts for penny's before setting up the mill and actually cutting the part from metal.
![]() ![]() Some of the machineing, this time I completely let the computer generate oath and speeds,, worked out well ![]() ![]() ![]() Have to machine bottom side and one side opp for the pivot pinhole.
#2056
Look at you with your fancy tools hey?lol Awesome work as always. Let me know when you get the suspension figured out so that I can order some.
#2057
![]() Just for you reg ![]() I think it will work?!?!?? Lol!!! Have been meaning to Email you and harass you!!!
#2058
#2059
Looks too me that you have two 3d printers , one for plastic and one for metal....one which can only add material and the other can only remove material to make a part!!! Nice!!
#2060
On my journey home yesterday, I stopped in to have a visit with Cooper. I managed to get through security by infiltrating the giant watch dog and little Bulldogs by letting them slobber all over my face
Currently Active Users Viewing This Thread: 28 (0 members and 28 guests) | |
