Old 08-18-2017, 12:22 PM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hofabooz is on a distinguished road
Default Re: Bruder small Cat conversion
Hi Skeeter
Looking good this is, cannot wait to see video of in out in the wild doing what its made for.
Mark
Regards
Mark
Over the Pond in the UK
Member of Ribble Valley Radio Controlled Truck Club
my weather station
Old 08-18-2017, 06:54 PM
Originally Posted by Hofabooz View Post
Hi Skeeter
Mark
Just a video on the garage floor for now. I've got a few glitches to figure out, before I can send it out to work!
https://youtu.be/6nk0oX4gv6k
Old 08-20-2017, 11:05 AM
I had time this weekend to run it a bit. I've decided to scrap the current version & start over. I didn't even get a full battery pack through it, & had issues. The drive axle in the Tamiya gearbox doesn't hold up well. It keep flexing, & slacking the tracks. Also, it would frequently bind up, & briefly quit driving.
Old 08-21-2017, 04:18 AM
Hofabooz's Avatar
Hi Anthony
That is what the hobby is all about try it see if it works if not change it and move on.
I'am sure it will be better for another revision and new ideas.
Looking forwards to seeing it progress.
Regards
Mark
my weather station
Old 08-21-2017, 11:27 AM
I'm NOT sure if it'll show up, but here's a few pics of the Tamiya Xmish after I got one with it.
The Small blue gear ONLY has 3 teeth left on the whole gear!
20170820_221853 by Anthony Kalnoski, on Flickr
20170820_221926 by Anthony Kalnoski, on Flickr
Old 08-21-2017, 11:30 AM
Since I already have this one chopped up, for the way I intended to convert it, a little more chopping won't hurt.
20170820_221741 by Anthony Kalnoski, on Flickr
I intend to try micro METAL geared servos to drive the sprocket cog, that turns the tracks.
Old 08-21-2017, 11:46 AM
As promised, here's the SHORT vid of it on the garage floor.
Old 08-21-2017, 11:51 AM
I found a micro HiTech metal geared continuous servo, that's compatible with the 24 teeth servo horn. RobotShop.com offers the servo, & servo horns that I'll try and use for the next attempt to power this thing. The brand new Bruder D5 chassis should be here tomorrow, or the next day.
Old 08-21-2017, 11:55 AM
Hi Anthony
Yes sir, I hope the next version is better as well!
Old 08-21-2017, 09:12 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
I went thru no less that 5 variations on my Oliver diecast conversion. I started with servos, went to micro gear motors and have finally ended with mini planetary gear motors and it working really well.
Keep at it, if nothing else (like me) you will learn something you can apply to some other project.
I don't mind seeing the "failures" it helps me learn also!
Jim
Old 08-21-2017, 10:11 PM
frizzen frizzen is online now
Ouch.
Video looked like it was really fast, maybe that caused too much shock load for gears? Good luck on round 2.
Old 08-22-2017, 08:23 AM
Ouch.
Yes, it was too fast.
Old 08-22-2017, 08:38 AM
Jim
I've thought of gear motors, but haven't found any that will fit. I'm real limited with the amount of room on the inside for motors.
SmallHaul, on here does a conversion of these, & in the description of his Youtube vid, it says he uses servos for the drive motors. I've sourced a continuous servo that has a spline that allows me to use the style of mounting brackets I'd like to use. HOPEFULLY, with this set up I can get it working.
I've already learned a fair bit. I as well like seeing OTHER PEOPLES failures so I can learn from their mistakes. I don't like it so much when it's my time & money wasted to find failure. Most everything on this forum that I found for a conversion like this has Photo Bucket pics. Photobutt ISN'T letting me view the pics of the builds Without pics/vids of their successes, &/or failures, it's difficult for me to know what has, & hasn't worked. I learn better from pictures than reading about it! I learn even better when shown while it's done AKA videos &/or being shown in person
Old 08-22-2017, 08:47 AM
I DON'T know if the small N20 gear motors would be sufficient for this build or not. If the servo idea doesn't pan out, perhaps I'll attempt it with a couple of them. I don't even have a clue what RPM would be well suited to this build. HOPEFULLY the servo idea will pan out. I've seen vids of the stuff that SmallHaul has converted. His looks good, & are very functional too. I'm sure with a lil tinkering, I can figure out how to get them servos to work for my drive motors too.
Old 10-29-2017, 10:50 PM
This, as well as all future builds/conversions I'm doing, are from now on going to be merged into 1 thread. The progress of this can be followed here
http://www.rctruckandconstruction.co...ad.php?t=12786
