Old 09-07-2017, 08:11 PM
Having seen your previous work, I know that when it's all did & done, it'll be well crafted, & look amazing.
Old 09-07-2017, 10:24 PM
Originally Posted by tc1cat View Post
nice axle. You do like LARGE vehicles!!!!
I should have guessed.
BIG DUMP TRUCK + BIG LOADER=LARGE MATERIAL OUTPUT 🍻
Old 09-07-2017, 11:19 PM
me thinks RW is getting serious about diggin out the barn & getting an INDOOR play area!
Old 09-18-2017, 10:27 PM
Cooper's Avatar
Cooper Cooper is offline
Thanks skeeter, and yes!! Have the perfect project for many years to come. Once I get the time I'm going to make an indoor screening plant. Large scale!! Well still scale to our equipment but want to move a lot of material. I have a lot of dirt that has been dumped for fill from rock raking /seeding yards. Perfect to haul into barn and then use the scale equipment to process. And best part I'll gain that wasted soil back. Might take a couple weeks to process a couple yards and then just a couple scoops with 1:1 equipment . But it is an endless supply with a purpose. !!
Old 09-19-2017, 01:28 AM
That'll be great to see you fab that up Cooper... you build a Vario sized excavator & a couple cubes could be done in an afternoon.
Old 09-19-2017, 09:46 AM
bigford's Avatar
bigford bigford is offline
That payloader will move more material then any
Excavator could
Old 09-19-2017, 06:01 PM
TRUCKMAKER's Avatar
That axle is looking good RW, looking forward to more updates!
Old 09-19-2017, 10:20 PM
Cooper's Avatar
Update,, still have some minor things to change but gettin the gist of it.
The drive shafts are long, they will be cut to size later
And I left enough material in relation to rims and hub to be removed if tires shrink more than anticipated from the mold process. That's kind of difficult to calculate precisely. (At least for my redneck engineering) ����
Old 09-19-2017, 10:23 PM
Cooper's Avatar
Oh and bearings will be farther onshaft for a retainer to keep them. I just don't want to pres them in yet. And I'm going to eliminate the chamfer between the two axle parts , I don't want that gap. Like I said still working on some fits and tweaks
Old 09-20-2017, 07:56 AM
kerst's Avatar
kerst kerst is offline
Beautiful!
Kerst
Old 09-20-2017, 09:00 AM
That software for your mill opened so many doors for you.
Old 09-20-2017, 09:35 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
About how much machining time do you have in 1 axle? Your machining is outstanding!!
LYNN
Old 09-20-2017, 10:48 AM
Cooper's Avatar
That is a hard question to answer, many parts,,, with wheels, probably around 12-13 hours? But I'm still learning and playing with numbers. Like the axle extension part that I.d. Of bearings slip over I had 1.5 hours in machine time. But now getting specs on insert and cutter I can probably drop that down to 45min. And another tool path I was using cutting speeds same as rapids and that took a 1hour program down to 30min. But I'm not breaking or pushing things. Lots to learn for a simple mind like me. And lots to improve speed up on. But I'm not trying to speed things up as in a production environment but just hate to see slow movements when tools are not engaged in a cut. . And after the initial program was proven to do what intended. The bearing pockets were a few trial/error and sneaking up on proper clearences to get them a snug hand press fit. Wasn't using a boar tool just path and the tollarances on machine are pretty good. I'd say I get a good 80% score mark all way around bearing pockets. Good enough for me .
Old 09-20-2017, 12:03 PM
JAMMER JAMMER is offline
Great work CB. Shows you are paying attention to the little things. Ed
Old 10-21-2017, 03:29 PM
Cooper's Avatar
Been a while so some data dump,,,
The back axle trunnions,
Steve (Ihbuilder) gave me the good idea of pressing on a piece of stainless for the bushing. Now the bushing material will slid against steel instead of aluminum. Thanks Steve. The back axle oscillates something like ?? 10 degrees.
Old 10-21-2017, 03:33 PM
Cooper's Avatar
Front axle/frame mount
I still have to drill holes in axle. Wasn’t sure about how everything was going together at time. Still have a bit of the redneck engineering, build parts first then figure out how to fit them together !!!
Old 10-21-2017, 03:38 PM
Cooper's Avatar
And now working on the frame that pivots along with mounts for turning rams
Building them to accept a tab and slot construction that will align and be welded together . On the 1:1 no hardware is visually in frame as they are cast and welded pieces. So I didn’t want any screws visually and welding is needed.
Still have to cut holes for the steering rams and bolt holes. These pieces required 6 different set-ups. Time consuming,,, as another said welcome to the machineing world
Old 10-21-2017, 03:51 PM
Wow There are several leagues in this hobby, and you are playing with the very best. Looking forward to more pictures.
Old 10-21-2017, 04:43 PM
The side extension supports[/QUOTE]
Me not being a machinist, how do you separate the milled supports from the base strip? Do they require another step to get to finished thickness?
Old 10-21-2017, 04:46 PM
This build is amazing.....and huge! Looking forward to seeing it in person one day. Think it will make Cabin Fever 2018?
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests)
