#341
Yes sir that it is. I wish I would have found a battery pack with a plug like that on it. it would have saved me a LOT of headaches.
#342
![]() ![]() ![]() Now I have everything needed to finished the New Bright tractor conversion. ![]() This one cost 3 times ![]() ![]() ![]() |
#343
#344
That’s a bummer. Atleast you have the correct ESC ordered now. Did you have a chance to install your new track motors on the 4200 ?
#345
No sir, I've yet to get around to the 4200 upgrades. Washington weather this time of year doesn't allow for much play time, WITHOUT an indoor play area. Since I don't have indoor play area, I haven't touched it.....yet.
#346
I FINALLY finished the tractor
![]() Frizzy, you sir were correct about the connections on the cheapo ESC's. ![]() ![]() https://www.youtube.com/watch?v=30tb...ature=youtu.be |
#347
Looking good, maybe a bit quick. But it is Turbo Tractor.
Hay wagons suck to back, the short tongue on that makes it even worse.
#348
Really sucks to back it. It's even worse then backing up the millennium style dump trailers, as the tongue is SO short on this wagon. The video was shot in the TURBO gear for moving down the roadways from field to field. I didn't get video of it driving in the farming gear. The bad part, the gear selector is on the rear of the tractor, just above the 3point hitch. There isn't enough room for me to figure a way to servo activate it. Guess lil skeeter will have to get off the tractor every time it's necessary to change from farming mode to get er done mode(s).
#349
![]() ![]() Those are the pins that keep the drive sprocket connected to the motors. I started to replace the motors today. ![]() ![]() |
#350
If anyone needs/wants a set of 4200 stock drive motors, send me a PM, & we can negotiate terms. I no longer need them, thanks to Rimrock AKA Soyland Industries & his upgraded motor kit he sells. Here's a link to the BST thread with them in it. http://www.rctruckandconstruction.co...ad.php?t=13070
Last edited by skeeter; 01-24-2018 at 11:37 PM. Reason: added link for BSt thread |
#351
Yeah I also had to bore out the motor brackets on mine. Dropped them off at a local machine shop and guy did it for 25$ for both brackets. Picked them up 2 hours later. I too tried doing it myself with a dremel but quickly lost patience.
#352
I'm glad I'm NOT the only one that decided it's too big of a project to tackle on my own. As far as cost, I've no idea what that will be.......yet. I hope it's NOT too big of a surprise!
#353
Check out this video! I like it, showing how to make 2S, 3S, & 4S batteries.
https://www.youtube.com/watch?v=zsxVbwgALiw |
#354
Here's a neat & simple video to make the XT60 connectors EASIER to unplug
https://www.youtube.com/watch?v=ap8qlzApfzo |
#355
Also found this neat lil vid of how to remove a cell from a LiPo that has a bad cell.
Yeah, I'm a lil bored tonight, & have been on YouTube learning a bunch tonight......Well, I hope I'm learning a lot. I know some vids there give miss-information. https://www.youtube.com/watch?v=jaaF84KFAek |
#356
hi skeeter did you ever receive that 1/16 army truck off of ebay? I haven't gotten mine and I see the seller is suspended so I'm trying to get my money back. was wondering if you had any luck?
eBay just refunded my money. took maybe 5 minutes. Last edited by Efroeh; 01-26-2018 at 04:31 PM. |
#357
Yes sir, I got mine. I now have 2 of them. The original that I pre-ordered (forgot where I pre ordered it from) AND the one I bought from Evilbay.
#358
Well, I tried to make a lil progress on the Weyerhaeuser logging truck yesterday.
#359
Here's a picture of the print that I took them. This had the measurements that I wanted, and the current dimensions written on it.
#360
Since they suck, try this with mspaint and word
http://www.rctruckandconstruction.co...ad.php?t=11281 post 22 Also, do you have tire height and axle witdh on the m35 yet? I had an ebay scam shutdown the one i had coming.
What do ya mean "Cars are neither Trucks or Construction"? It's still scale, and i play fairly well with others, most of the time... Last edited by frizzen; 01-27-2018 at 09:38 PM. |
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
