Old 03-10-2017, 10:36 AM
Stuart's Avatar
Stuart Stuart is offline
Stuart is on a distinguished road
Default Re: Joskin KTP27/65 Tridem
Originally Posted by porky69 View Post
I just watched a couple of videos on http://www.joskin.com/?page=transpor...7&user_lang=en and from what I saw it(the 1:1 version of what this one is modelled off of) works pretty much exactly like I described so I don't see why with a little fine tuning on linkages that the model would be any different.
Exactly what I was going to say
I think I have a bit to much steering angle at the moment but with a bit of tweaking should be spot on.
As for "Extreme Terrain" Joe, its not a rock crawler
Old 04-11-2017, 02:10 PM
Stuart's Avatar
A small update:
Old 05-08-2017, 05:12 PM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hofabooz is on a distinguished road
Hi Stuart
Looking good man looking good cannot wait to see it in action.
Regards
Mark
Over the Pond in the UK
Member of Ribble Valley Radio Controlled Truck Club
my weather station
Old 12-14-2017, 12:56 PM
Stuart's Avatar
Been awhile but made some progress:
first hydraulic test: video
Thanks for lookin
Old 12-14-2017, 02:13 PM
markturbo markturbo is offline
markturbo is on a distinguished road
Good to see you're back at it. Any more pics from the ones missing on the first page?
Old 02-12-2018, 01:40 PM
Stuart's Avatar
Have you seen the link that Bo Wallen posted about the photobucket workaround? It worked for me.
Some more progress:
Couple of vids:
Video 1
Video 2
Stu
Old 02-12-2018, 07:44 PM
Very nice work, great to see something out of the ordinary. Who's hydraulics are you using?
Old 02-12-2018, 11:57 PM
I like it! it's looking good.
Old 02-13-2018, 01:01 AM
24Bar... will you be putting compression collars on your fittings upon final assembly?
Old 02-13-2018, 01:42 PM
Stuart's Avatar
Thank you, I'm using a combination of Magom and Chinese stuff.
Thank you
Yes Joe I will, they're sitting in a bag on the bench, I put one on the cylinder lift pipe then forgot the others doh!
Mind you, whilst setting the pressure relief I had it up to 30+ bar with no issues...but for piece of mind I will fit them.
Do you think it needs them on the return side?
Did a little sheet bending tonight:
Old 02-13-2018, 01:50 PM
now it REALLY does look like something. This thang will be an when completed!
Old 02-15-2018, 06:31 AM
Return side? Yes, you will max pressure when cyl deadheads for a second or two... might get away with it for 20 - 50 lifts, but that hyd line is always ever so little ballooning with pressure... better safe than oil spraying everywhere, no fun to clean up.
When you disassemble for paint, do you cut the hose off the barb or force-ably pull it off? ...I always split the hose with a #11 knife off the barb.
What's the loading height of your box from the ground?
Old 02-15-2018, 01:40 PM
Stuart's Avatar
No your right, been there, done that!
So ok I'll fit to all the 3mm hoses.
Yes I have to cut them off the barb with a craft knife, no way you can pull them off, once they're on they're on.
Loading height is 185mm
Old 02-15-2018, 01:42 PM
Stuart's Avatar
Thanks skeeter, not sure what you meant to say it will be though lol.
Started the tail gate:
Old 02-16-2018, 12:00 AM
LOL, yeah, I make a LOT of typos
SHOULD have read that thing will be AWESOME when completed. SOMEHOW, that part got deleted as I was typing it. I HATE them keyboard hotkey things. I DON'T even realize that I've accidently hit one of them, or for that matter what combination of keys I hit to make ti do that!
Old 02-18-2018, 07:20 AM
Stuart's Avatar
Ha ha, I know what you mean lol.
Got the front end done, just the sides left to do then glue it all together:
Old 03-01-2018, 01:58 PM
Stuart's Avatar
Wouldn't fit in the oven so had to improvise lol
Old 03-02-2018, 12:41 AM
Well that's taking shape nicely Stuart
What glue did you use?
Old 03-02-2018, 12:08 PM
Efroeh Efroeh is offline
looks great can't wait for updates
Old 03-03-2018, 01:23 PM
Stuart's Avatar
Thanks guys,
Joe I used UHU endfest 300 plus 2 part epoxy, the hotter it is the quicker and more importantly, stronger the bond is.
I applied the glue at room temp (approx 20*C)
The top of the stove was 274*C and the trailer was around 70*C
