Old 03-18-2018, 05:36 PM
Default 3d printed lowboy conversion version 2 detachable gooseneck
ok, tried some other files. thanks to EFICKER again on thingverse, this is the same as version 1 except for larger pieces where they attach to the flatbed, and removable gooseneck. i modified this one's gooseneck to be in 4 parts like the 1st trailer as my print bed is not big enough. i also modified the rear bed piece to have a slot so the wood slats could sit recessed a bit. on to the pics.. don't mind the bent wood, still need to trim them down, most of the pieces are at 80% fill, probably 50 hours of printing time.
time to load er up
hmmm we might need a bigger boat.. lol
loaded up and truckin
hey look, we found a friend
here's the 2 side by side version 2's neck is a bit longer which is good, i might modify the angle as the front is a bit close to the ground
Old 03-19-2018, 06:42 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: 3d printed lowboy conversion version 2 detachable gooseneck
Are you loading the files from thingiverse into your cad program and changing them to print what you need? What software are you using?
Jim
Old 03-19-2018, 08:04 AM
pretty much, if it's a good model, i can go from thingverse to the slicer program for the printer, but to modify i use straight autocad, autocad fusion 360, tinkercad, meshmixer, whatever it takes to get the results.. lol and some are just for conversion from one file format to another.
Old 03-19-2018, 08:06 AM
Rvjimd's Avatar
Looks good! You probably mentioned above, what filament and printer are you using?
Old 03-19-2018, 10:37 AM
printer is monoprice select plus (wanaho duplicator i3 clone) i started with 1.75 pla from monoprice, but i'm trying pla plus as it's supposed to be better, running axle housings now
Old 03-19-2018, 05:13 PM
I'll be anxiously awaitng a report of how much weight this can carry WITHOUT breaking, OR dragging the belly on the ground! I'd LOVE to make one of these for carrying the RC4WD 4200XL excavator around, &/or the Bruder D10 conversion
Old 03-19-2018, 08:01 PM
i doubt it would handle an all metal excavator, remember the backbone is the aluminum floor of the flatbed. i might try some i beams, but this is for light weights only i think
Old 03-19-2018, 09:27 PM
frizzen frizzen is online now
If there's room below, some c channel should help stiffen it up
https://m.lowes.com/pl/Trim-channels...are/4294684419
Old 03-19-2018, 10:29 PM
if we could find i beam or c channel the height of the plastic supports under the wood, that would be perfect
Old 03-19-2018, 11:03 PM
Cooper's Avatar
Cooper Cooper is offline
Look for architectural extrusions , I forget where but I found some h-beams of alum. Thin stuff but strong. I'll see if I can find where. A couple pieces like that would probably give you the major framework to build around and support heavy loads. I'm still amazed with the printers.
Old 03-20-2018, 07:58 PM
Thanks fir that tip! I'll anxiously be awaiting to see where to order the "H" beams from.
Old 03-21-2018, 08:13 PM
Jakyat Jakyat is offline
Jakyat is on a distinguished road
Cool Re: 3d printed lowboy conversion version 2 detachable gooseneck
You might be surprised to find out that with the right supports and bracing in the right places will allow a good payload. Remember alot of our 1:1 equipment trailers are built smart and made of light materials with lots of flex. I really like what you've got going there. you should consider a flip over neck extension and jeep for one of these.
Old 03-22-2018, 05:59 AM
ramjetexpress ramjetexpress is offline
ramjetexpress is on a distinguished road
where did you get the files to print the rear fenders on the truck shown on top of the trailer . I cant find them
Old 03-22-2018, 07:59 AM
i forget whose fenders those are, might be PMD, they are vacuum formed styrene i think, they don't feel like 3d printed. the hood is on that truck tho, from shapeways
Old 03-22-2018, 10:48 AM
shorter gooseneck and weight test:
i shortened the gooseneck vertical pieces about 4mm, this picks the front end up a bit. new material is pla plus, thicker layer size and less infill. i don't like it as much as regular pla
also realized that the horizontal pieces need to be longer, or that flip over tongue needs to be designed
ok here's the weight test, this bucket is 14 pounds, flattened the trailer right to the ground..
here's a couple shots with starbuck's bottles, each one is 14 oz i think, still pretty close with all in the center
here they are spread out, didn't help much
here's why there's so much flex, there's no longitudinal stiffeners other than the outside L shape aluminum
Old 04-01-2018, 10:28 PM
Fury Fan Fury Fan is offline
Fury Fan is on a distinguished road
Mcmaster.com has a bunch of extrusions, not as many as an extrusion manufacturer, but McMaster has pricing on their website, no (or very low) min order amount, and sells to citizens via creditcard.
Much of my RC odds/ends/hardware, and mad-scientist-handyman stuff, comes from there.
Old 09-14-2018, 03:16 PM
Trio Trio is offline
Trio is on a distinguished road
how do i buy these parts. what website
Old 09-14-2018, 03:31 PM
you have to make them yourself. i was thinking of making kits to sell, but it would not be profitable.
monoprice.com for the printer, thingverse.com for the files
alternatively you could download the files from thingverse, modify as you see fit and upload to shapeways and they will print for you
