Mechanical tech This is for the mechanical parts of a model. Gear reductions, Axles, Transmissions, General drive line |
In the instructions for the Grand Hauler there is a note telling NOT to replace two bushings with bearings. Is this a definite no, no, or is it okay to replace with bearings? Here is a picture.
![]() Thanks, Big John.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
I've replaced them before without any issues. I've never had to glue them either.
Yeah I didn't understand the change either. But then again looking at my king manual it doesn't tell you to glue them in either. So my only thought is they are worried about people getting glue on a ball bearing causing it not to roll which would jam everything.
If I remember the gear box internals correctly, the reason it's advised not to replace with ball bearings is that those bearings need to both slide and roll freely. Ball bearings are usually not very good at sliding. Glue prevents them from popping out of the plastic thing from the push/pull force.
I have a feeling I greased that instead of gluing in my current build. Thanks for the reminder to check. |
![]() Big John
I am building my first KH and just finished the trans. Installed bearings throughout just prior to reading this thread. I have 1 bearing not sliding well, and I agree with Wombii. I'm going to swap those 2 bearings for the Tamiya bronze bushings.
Ball bearings are an unnecessary upgrade & a waste of money, the oillite bushing - bearings are way better & last much longer, especially in the drive axles, ball bearings wear out, oillites won't.
