Hello all; I’m at the motor mounting/motor audjusting state and I’m wondering what is a suitable gear mesh for the main drive train? Here is what I have now and I can slide a piece of printer paper through easily enough but not too easy
HI
No I cannot see the picture try again please
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
How’s this
WTH? It’s not working when I want to post a pic?
Test
Basically you just want a very little amount of play. If they are tight it will cause premature wear and excessive motor load. Too loose and premature wear quicker. A piece of paper cut close to same width of gear then ran between gears is basically what I do. Newspaper is thin, printer paper should do. Sandwiche it between gears tighten up and rotate it out.
https://youtu.be/xFGy8RARHN4
Ok, will do. I already put the printer paper through it and it went through cleanly. Not too loose, and not too tight.
Cool! Just did as your video said. That helped a lot, thanks!
