Old 02-10-2018, 01:26 PM
Rimrock Rimrock is offline
Default Re: Bucyrus Erie 40H Excavator 1:14
just a small note, would advice a bigger turning motor, same as the track motors you've got (another gear ratio) Such size gearmotors are the 'standard', and about got enough power (but could be even more powerful)
Soyland Industrier
Old 02-10-2018, 01:59 PM
Machfab Machfab is offline
Machfab is on a distinguished road
Was going to try the small one first and then go to the larger one if needed.
Old 02-13-2018, 02:07 AM
Looks HUGE!
What's your boom/stick weigh?
The boom/stick of the Vario are paired 5mm plate steel incased in GFR, they're heavy! (don't know weight) A combo of EPA & curve in radio settings, the movements of each are smooth with twin 18mm bores on the boom & 22mm on the stick @35Bar - 1.8L flow
Old 02-14-2018, 06:28 PM
Looks HUGE!
I would guess about 8 lbs. I will test “as-is” and then reduce weight if needed. I don’t think hydraulic power will be a problem.
Old 02-15-2018, 06:02 AM
You making your own hydraulic system too?
Old 02-15-2018, 06:44 AM
Planning to use Magom cylinders and RC4wd pump.
Old 02-15-2018, 07:26 AM
That'll be interesting to see how that combo handles the high pressure
RC4WD valves too?
Old 02-15-2018, 07:28 AM
RC4WD valves too?
Yes, RC4wd valves to start with. If problems arise, I will make my own or improve what I have.
Old 09-06-2018, 07:58 AM
3D Printed cab parts
IMG_0631[1] by Lyn Byrd, on Flickr
IMG_0630[1] by Lyn Byrd, on Flickr
IMG_0629[1] by Lyn Byrd, on Flickr
Old 09-06-2018, 06:59 PM
Really glad to see work is continuing on this. Great job, please keep posting updates.
Old 09-17-2018, 07:51 AM
More progress. Added hydraulic cylinders and bucket.
IMG_0642 by Lyn Byrd, on Flickr
IMG_0643 by Lyn Byrd, on Flickr
IMG_0644 by Lyn Byrd, on Flickr
IMG_0645 by Lyn Byrd, on Flickr
Old 09-18-2018, 08:49 PM
Looking goooooooooooooood!
Old 10-01-2018, 01:49 PM
What would be a good radio for this model?
I was thinking about the Radiolink AT10?
Any input appreciated
Thanks
Old 10-01-2018, 11:51 PM
Jared Jared is offline
Looking good! Love seeing older equipment get built.
Old 10-09-2018, 10:38 PM
Thumbs up Re: Bucyrus Erie 40H Excavator 1:14
I as well love to see the old stuff being brought to life!
Old 12-08-2018, 08:16 PM
VIDEO Diggin in the quary!!!
IMG_0703[1] by Lyn Byrd, on Flickr
Old 12-11-2018, 11:17 PM
It's not letting me see the video, fo rsome reason. Have you considered a YouTube account for posting videos?
Old 12-12-2018, 06:39 AM
Try this
https://youtu.be/ZL8PREyACIY
Old 12-12-2018, 09:31 AM
Originally Posted by Machfab View Post
Much gooder, it plays now. That's AWESOME! I took the liberty of sharing the video to PNWSTE facebook group.
Old 12-16-2018, 03:43 PM
You got it working good job
Swing is pretty slow, what rpm did you use there?
Hydraulic speed seems ok... to help preserve battery time, radio mix valves to cylinder chs so pump motor slows to 20% idle speedwith no stick no movement. With these rather large outrunner brushless motors on the hyd pump, there's certain amount of stall amperage to start them, so always have pump motor turning so you don't cook your esc.
The stick cyl, at the back of cyl, was the pin mount machined into the boom? ...if you could your stick cyl back about an inch, get your stick to fully stretch out.
It's looking good, keep at it.
