Mechanical tech This is for the mechanical parts of a model. Gear reductions, Axles, Transmissions, General drive line |
Current project needs a rear axle with differential. Tamiya/Lesu diffs are physically too large. The 1/18 axles I have seen don't have diffs.
Suggestions requested. Thanks!
Big iron is awesome! |
Lesu also makes 1/16 axles with locking differential. They are fysically smaller then the 1/14 scale Tamiya ones. In Europe they are sold under the Thicon brand: https://www.thicon-models.com/thicon...b-sperrbar-3_1
You may want to look for the original branded Lesu ones, but the sizes are mentioned on the Thicon site, so you can check if they are right for you. The quality is good for the price, and the locking differential works really nice off road.
Greetings from Holland, William |
Thanks! I will take a look at them.
If price matters, check out Aluminum axle upgrades for JJRC 1/16 trucks.
They match the 1/16 WPL axle dimentions enough to be interchangable to the rest of those chassis. Have 5mm wheel hex. The pumpkin is bigger to fit the Geared open Diff instead of Spool. What are ya building?
I'll second Frizzen... JJRC even has a metal upgrade for the differential internals
Frizzen & jerry56: thanks for the info. I have looked at the JJRC Q61 truck and it shows the differential but I'm not clear which assembly I should get nor which aluminum housing I need - the Ebay descriptions don't have enough detail for me to be confident when ordering. Would appreciate your advice.
Thanks!
Here is a complete 4x4 set with Differentials... looking at them these fit the WPL housings not the JJRC so you could skip the JJRC entirely and go with these
https://www.aliexpress.com/item/4000...mend-recommend Now if you already have a metal WPL axle set here is the rear differential to put in them https://www.aliexpress.com/item/1005...mend-recommend And this is the front https://www.aliexpress.com/item/1005...rch-mainSearch And all 3 https://www.aliexpress.com/item/1005...mend-recommend Last edited by jerry56; 04-03-2022 at 03:51 PM. |
Ok you said q61, so you want a 2 axle truck?
--The rtr trucks have plastic guts, plastic housings, with '2 screw' diff covers. -- There's an upgrade with plastic housings with '4 screw' diff covers, this has metal gears with bearings https://m.banggood.com/2PCS-Upgraded...lixnkid=776878 You can get plastic guts in plastic housings, metal guts in plastic, or metal guts in metal. Good luck with translations, it gets pretty creative Pretty similar 1/16 trucks with parts compatibility: WPL, JJRC, MN, Fayee Jerry, cool find. I didn't know there were any WPL axle sized working Diffs
It's odd but sometimes there are things on Aliexpress that aren't on Banggood....I used to use banggood all the time but I found Aliexpress cheaper...in some cases a lot cheaper.
Thanks for the assistance. Just ordered.
I'm converting a 1/16 diecast GMC flatbed straight truck. Ken
For some reason EVERY time I try to order on Bangood, my financial institution declines the charges to my card! For that reason I switched to AliExpress for most things that I don't urgently need. They seem to have some really SLOW boats these days!
Yes on the slow boats! My order estimated to arrive May 4.
Ken:
Did you ever get your diff's, and if so how they working out? Don |
Yes. Recd & assembled. Look good, just have to get back on the project and decide what leaf springs I want to use.
Are you still working on this one...any updates...
Sparkycuda:
Any updates on your die-cast GMC straight truck conversion? Ever decide which springs to use? Don |
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
