#41
Very awesome to get to get to see this off the bench and moving!
Mmm, counter-steering. Could you set up a way to toggle a mix to also allow Crab steering? If you don't have any tire scrub on turns, you're already doing way better than fullsize JLG bucket lifts
#42
Originally, yes. Now I'm going to skip all together. Less wiring and the inner motor is able to bog down to match speed. Crab steer is a must! It should be pretty easy to setup on the radio. It's the feature I look forward to the most when placing stuff with the forks. I'll do a front steer only as well for high speed travel. |
#43
#44
Progress dump one what I've accomplished while the site was down:
![]() ![]() ![]() ![]() ![]() ![]() ![]() Machine is fully functional now. Wiring is mostly hanging out the side before I condense it all. Hydraulics are really smooth although slightly slow. Since I'm only on 2S lipo I should have a slightly higher kv pump motor. Not going to change anything. Works great as it is. Did add a step up voltage converter to get a steady 12V for the drive motors. Woke them up and make better torque. Will still swap in a set with deeper reduction. Crab steer is my favorite feature when placing a barrier inline. A fun little machine |
#45
Really looks good, great progress. Am glad to get to see more.
#46
Looks like really good use of the site downtime!
Great looking construction fleet
#47
Thanks guys. I'm really happy with this machine. I've been slow to start painting since it's too much fun to play with.
Currently Active Users Viewing This Thread: 39 (0 members and 39 guests) | |
