Farm Tractors and Implements Discussion of farm equipment |
What rims are you guys running on your Tamiya semi truck axles, when you do these tractor conversions? There is a wealth of 2.2 sized rims out there, that fit 12mm drive hexes, but the set I ordered and received have way to much positive offset to fit my axles and allow clearance for the tractor frame. I need a rim with more negitive offset (with the hex not set so deep into the rim) or wheel wideners. I do have a set of Clodbuster wheel wideners, that will fit the 12mm hex just fine, but I'm also looking for other rim options. Something that at least looks kind of like a tractor rim.
The ultimate would be a custom machined set of rims, out of aluminum, but I am sure that's going to be expensive, and I don't even know who to talk to for something like that. Mean time, I'll run the wideners I have, but I am open to any suggestions.
Nathan |
I am with you on what you are wanting I think. You want the rim to bolt on and be further from the tractor for clearance right? The front wheels of the TRAXXAS Rustler/Stampede have a lot of negative offset and to make them look better use a hole saw and cut out a plate to fill in the center. Here is a link to them Click Here
"I don't even know who to talk to for something like that." yea you do
Travis, those rims for the tractors that I've done here lately bring the tires in to close,& will rub on the inside of the fenders. The one's that I glued the hubs into are perfect. As soon as I get back into town I'll give you the part #. It's also going to depend on which tractor your doing.
Espeefan,you might want to build the machine,or at least get the axles mounted.Then do some measuring before you order rims. Or you could be like me & are now sitting on 3 sets that don't work! ![]() ![]() Which tractor are you thinking of doing? I thought you said something about one of them red ones. FGD
Well your best bet is to get off the computer and go down to your LHS and see what they have that will work.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() You can go to Toy Farmers web site Link and look for shows that will be in your area and there are usually a few different vendors there selling tractor parts. Travis
![]() Like I mentioned to Travis, I got mixed up and ordered the wrong rims. They were cheap though, and I can still send them back. Or use some wideners I have laying here. What I'd really like to do is narrow the Stampede tires I have and stick with the duals. Have to see. Seems all these 1/16 scale tractors have about the same frame width. The Tamiya axle's mounting flat (with the holes for screws) are just a smidge wider then the tractor frame. Quote:
Nathan |
Espeen
the other place to ask about custom tractor stuff is on pirate farm toys site.
Daniel |
U should look into the tellebrog 850 tires for ur case like on my stegier. The tires are real soft and grip very well, but need to be glued or on bead lock rims. ![]() Last edited by rcguyfarms; 09-28-2011 at 06:24 AM. |
I had an extension shaft made for my and Pauls steiger. I will post a pic of it. That extension made the tires fits nicely back to the same stock with with the stock tires, using the tamiya axles. The tire mates to the back of the plate of the axle and is then secures with a lock nut. This kinda take away from the appearacne of the drive hub, but was the only way i could come up with at the time.
Giving up is not an option!!! Rob Last edited by rc_farmer; 09-28-2011 at 11:57 PM. |
"I didn't really know you were in the ag tractor rim business, Steve, but since you mentioned it, maybe we can talk. I don't know how soon my tractor will need rims. I seem to work pretty slow."
Nate I'm trying to get a shop with the right machine to run my blanks for the truck wheels to free me up on new designs . I have been asked ![]() ![]()
Tyler
~Tyler~
RockSolidCustoms |
![]() What do you think?
Nathan |
Rob, thanks for sharing your tricks and ideas, for these conversions. I appreciate it.
Nathan |
Hmmm you got me thinking
Nathan the stampede tires are the exact same height as the stock ERTL ones. And the width is the same as the 2 dual wheels. I know you dont want singles but they still look good on the New Holland...lol. ![]() |
http://www.standitoys.com |
Been reading some threads trying to figure out how I’m going to piece my tractors together been worries about how I was going to attach my tires to axles, I think this is perfect! Now just to get some made up
You are building this in 1/32, should interesting to follow. What are you using for drive gear?
