Anyone know where I can get some 8,9 or 10 tooth sprockets for # 25 chain W/a 5mm shaft size??
Thanks! FGD
Without looking, do they make sprockets that small? I thought 12T is about all the smaller in any pitch is recommended.
Freddy. These guys don't have an eight but everything else. Also close by for you.
http://www.tsubaki.ca/pdf/E14-80_Sma..._Sprockets.pdf Rob |
The smallest I have ever been able to find is 14 tooth sprockets, from Servocity, and you will need a hub to match the 5mm shaft you want to mount it to.
http://servocity.com/html/hub_mount_...ts___250_.html Or if you bore out a sprocket meant for a 3/16 shaft, you could get a 12 tooth, but you are on your own for mounting it, and it would probably have to be pinned to the shaft. http://servocity.com/html/plain_bore...s___1227_.html Here are the hubs I used for my 14 tooth sprocket. http://servocity.com/html/set_screw_hubs.html
Nathan |
McMaster-Carr & Robot Marketplace both have 9T & 10T. Grainger has 10T. Smallest bore available through any of these is 1/4"
Big iron is awesome! |
Yea, those are what I have now.A ten tooth is almost to big in dia for where it has to go.
![]() Guess I'll keep lookin for a while.If I can't find any,then looks like it'll be make bushing time. Thanks Guys for the sites! FGD
Can you use a cog belt instead?
Freddy stop wasting time and just bush it
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
