![]() ![]() I have been wanting to make a hauler for while. My inspiration was Microgoat's Rollback tow truck and Freddy Gear Drive's F350 Dually. Body... Axial Axles...
Wheels & Tires... Drive train...Specs...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. My Builds To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by justinart24; 11-11-2011 at 02:42 PM. |
The body is sitting a bit high, will try to be lowering it about .5".
![]() I will be using RC4WD seats. ![]() Not sure if I will be running the Tamiya Semi gas tanks but they look pretty cool. ![]() ![]() ![]() Make some leaf spring mounts out of steel, seems to do the job. ![]() ![]() Rear axle, might be adding two more helper springs....my scalers are pretty heavy. ![]() I also might be doing a sway bar setup on the rear axle, need to test drive it first before I do that. ![]() Close up shot of the sick RC4WD double trouble wheels. ![]() Rear wheels. ![]()
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. My Builds To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Lookin good so far! Have you givin any thought to makin this baby a rollback?
FGD
Got the design of the bed almost done.
Got a bit more work done. Funny thing, after running no mirrors on my scalers, it was kinda fun putting them on this truck.
![]() ![]() Filled in the back of the cab, now for some bondo. Also dropped the cab about .3". ![]() Got some F-350 emblems from RC4WD, dang there pretty sweet. http://store.rc4wd.com/F350-Highlift...et_p_1408.html ![]() Got part of the floor done. ![]() The cab mounts to the pieces of delrin. ![]() Under shot of the RC4WD R2. ![]() Shot of the drive line setup. ![]() ![]()
Looking good. I like it alot. Any updates?
Scott
I run a single stack Mack with a dump body on the back! |
That's looking good so far!
Gary |
Get r done Justin, We need to do a little trail ride adventure with the rigs
Whats the track width front and rear Justin ?
Man this build is looking good! Keep up the cool build! Jordan
Thanks, sorry no updates. Been working on redoing my workshop.
![]() ![]() Thanks! Quote:
Drive it huh, I am going go all Mongo on it and sell it so I can fund my next build
![]() Hope to see it in person soon. |
look very nice, i wanna see it done
Looking good I like the rear dually wheel set up.
good looking truck,were did u get the rims for?
Thanks, I am getting there. ![]() Thanks! ![]() Thanks!....Got he wheels from RC4WD. ![]() http://store.rc4wd.com/Double-Troubl...ls_p_1214.html
Picked up a super long driveshaft setup from gardentrucking.com
![]() Swapped in a Dinky RC hilux interior for the seats and took my Ford dash out of my F-350 Truggy. ![]() I wanted it a little stiffer in the rear so I put some shocks in. There some old tamiya TT01 shocks with SCX10 spirngs. ![]() Started the bed and headache rack. ![]() The styrene was just for testing, still need to pick up some more .5"x.15" wood from the hobby shop. ![]() ![]() Don't mind the tamiya semi bumper, I will be making a beefy metal bumper later. ![]() ![]()
Wow that's one sweet set up. I love the ford duallys
Very nice build!
"Experience is what you get right after you needed it." |
