#481
Looks like it would take a few hours to wear those buckets out Joe ! They must weight a few pounds..
greg |
#482
Not that heavy at all Greg.. it's all made from 20guage.
![]() Most of it is still there yet RT9. ![]() I made the steel bushings in my lathe to fit the 6mm rod.. weld in the bushings & front rod tomorrow, then paint 'em both. ![]() ![]() The GP bucket is 50% larger than the kit stock bucket, almost as wide as the 740 box. ![]() ![]() I wondered after making such a big bucket if it might be too big.. but even with the hoe sitting at a tilt, a bucket full didn't even make the outside track jiggle. (I filled the counter weight full of BB's last week, didn't weigh it though) ![]() ![]() ![]() ![]()
#483
No
#484
Looks good Joe, the bigger bucket will speed things up before the spring time rush. springs not that far away now and the dust will be flying soon.
Steve. |
#485
![]() ![]() ![]() ![]() ![]() ![]() The paint is not lasting long.. I used a metal etching primer too! ![]() I made a couple vids this week.. Travis & IHStevie, pay close attention to the wheel speed of the front vs back tires of the Komatsu when it's back blading from the pile at low throttle with the front axle in the air. ![]() http://www.youtube.com/watch?v=1GDwB-EeyWo 850 screening the wet lumps, then the adt stock piling the wet lumps behind the water heater.. had to use the board to climb the pile, trying to climb loose soil that steep, the adt just digs a hole.. getting it piled quite high back there. http://youtu.be/15xwKUVjyBw This big bucket is about 50% larger than kit stock.. move alot dirt quickly, especially from the far wall where it's quite a confined area to maneuver within. http://youtu.be/PvlvZXwxIqo
#486
Hey Joe, It amazes me, how abrasive clay really is! You may just have a super shiney bucket in no time at all.
Cheer's, Neil. |
#487
"Travis & IHStevie, pay close attention to the wheel speed of the front vs back tires of the Komatsu when it's back blading from the pile at low throttle with the front axle in the air. "
![]() I not sure what your trying to prove here ![]() ![]() OTOH , great job on your buckets . I always said ," an excavator is worthless with a small bucket in mass excavation " I had a 4' bucket on my Cat 307 (16,000# machine) As always I enjoy watching your vids ![]()
#488
Hello Joe,
That was some fine loader work in the video, nice control and very realistic looking. You can tell from seeing the loader work that there are hours of experience behind the sticks. Steve. |
#489
Your loader sure can move a lot of material in 15 minutes!!!
RIP FGD 12-19-11 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RCTech9; 03-17-2012 at 11:37 AM. Reason: extra question |
#490
![]() ![]() wdc to Stahl is not apples to apples... ![]() Well, different buckets for different jobs. That wide bucket with it's straight cutting edge will be great for grading as well. And I'm eagerly looking forward to trying that narrow bucket to dig on the wall, might be a lot less use of the ripper before hand. ![]() Thanx Steve.. yes, many hrs of practice & enjoyment. ![]() One of these days yep RT9, I'll probably brush paint them black while still attach to the model. ![]()
#491
Well I really can not say much for either , I don't have them or run them
#492
So I put my tireless working 6wd GL on the workbench for a tune up..
![]() Added some weight to the front axle, and added an extra fuel packed full of BB's, transfer more of that power to the ground! ![]() Off to the basement for a trial. ![]() The white GL pulled the B Train up the ramp with open diffs with very little slippage, but the HiTec 625 steering servo couldn't handle the extra weight hanging out in front of it & caused the rx to glitch like crazy whenever I tried to turn sharply. So I then installed a HiTec 645, as well as Castle Creations BEC.. these Tamiyas are so easy to work on. ![]() ![]() ![]() ![]() Testing it out on the bench, trying to go forward and the shift servo glitched crazily! didn't matter where I plugged the CC BEC rx lead into.. junked the Polk radio from this trk and used my extra DX8 rx.. trk is working better than it has ever before! Very smooth! Love these Spektrum radios. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() http://www.youtube.com/watch?v=rc4EmuKaL
#493
so joe where is this new machine you got in a box from frank
#494
Hey Joe ,that wieght bar should give you some nice grip on the front
![]() I used some small used and worn out carbide seats I use in the pumps I work on at work ,in my bruder excavator for counterwieghts,works great! Keep up the great work !! ![]() Tommy
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#495
Joe your a inspiration to everyone that is looking to get into the construction gear, thanks for sharing the pic's and info...
When you start doing the next round of servicing on the construction gear can you do a side by side comparison the good and bad of each piece in a new thread if you haven't done it yet???
RIP FreddyGearDrive 2-12-59/12-19-11 Love my Kenworths To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#496
Hey Joe, Can't get the video to work
![]() Have you considered a combination ripper/bucket? http://leattach.com/raptorbucket.html ![]() ![]() ![]() I like the heavy bumper ![]() ![]() ![]() ![]() Cheer's, Neil. Last edited by doodlebug; 03-25-2012 at 10:09 PM. |
#497
Still in the box Neil.. might start working on it this summer after the crop is planted.
![]() Yes it is working very well Tommy, better than having servo lockable rear diffs in the past. Thank you and your welcome Tracy.. what specifically would you like to know?
#498
Interesting design Neil.. one problem I see for me making this in scale would be that it might pack with clay too easily.. find out here shortly if the narrow bucket I just made will empty good or just build up with wet sticky clay.
It was working.. here's another link. http://www.youtube.com/watch?v=rc4Em...1&feature=plcp Might add three more bd's sometime in the future..
#499
Ok, I'll work on another idea for you later tonight!
Cheer's, Neil. |
#500
You are moving many scale yards of dirt each load Joe... Any idea how many pounds in each trailer ? Very impressive ! !
greg |
Currently Active Users Viewing This Thread: 34 (0 members and 34 guests) | |
