#201
Hey Reg, it's definately faster
![]() ![]() ![]() Congrat's on the new mill ![]() ![]() ![]() Cheer's, Neil. |
#202
I do have grease in the planetary but the original one had a plastic ring gear and the torque of the motor started twisting the teeth right off of it where the first set of steel planet gears made contact. The new set-up is all steel and has a bearing in it too instead of a bushing so hopefully that will help with wear and friction. It's a little too fast but at least I can dial it back a bit now.
The breakdown was a good excuse to use the mill though... Reg |
#203
Good video-It does seem to be faster now. I wish I had a load of dirt like that for my shovel but if I put a dirt pile like that in my back yard I probably would be looking at a-d-i-v-o-r-c-e
#204
Oh ****, I like it! Now it moves like a champ! Good job on that!
All the hydraulics were made by you? That new mill looks massive, BF30? It seems that it has got DRO installed already. Any plans on converting to cnc? |
#205
You be sure to post some pic's of your first projects off that sweet mill
![]() Agreed will above, speed looks very good. My local supply shop has some of the black hose similar to that used on your machine and I see yours too has green writing on it. The guys at the shop couldn't tell me the bursting pressure of it and didnt seem to motivated to hit the books ![]() Can you please let me know what's written on the black hose? I'd like to check to make sure its the same stuff. Glenn |
#206
All the hydraulics except for the pump were made by my father inlaw. We did sketches together of what I needed and he put it into reality for me. He actually made me a couple of pumps too but they didn't make as much pressure as I wanted so I bought the Jung and made my own drive for it. Now that I have this mill I hope to do this type of stuff myself but I need some(a lot) practice first! Thanks Reg |
#207
![]() I haven't really made much with the mill yet but I have drilled and tapped a couple of holes with it. It's nice to tap something right in the machine and have it straight for once! Reg |
#208
What type of hydraulic valve did you use/make?
#209
It's a rotary valve. If you look back a ways there are pictures of the one I made myself and then the final one my father inlaw made that we ended up using. It's time consuming to make them but quite possible if you have a mill and a lathe.
Reg |
#210
I really enjoyed watching your "IN CAB" video. Made me think I was in a 1:1 I also like the small stress cracks on your windshield. If only I could have turned the wiper on when it stated raining.
#211
![]() ![]() Reg |
#212
Wow, that works better. Glad you got the pump speed / volume figured out. Nice looking mill. I have been away and had to go see if my BF30 was still where it was supposed to be. You will love the bigger mill with a DRO. There should be no limit to what you can build now.
#213
![]() I think it will be good for my needs for sure. I would have liked to go the CNC route but I guess I can do that later and in the mean time I have a decent manual machine. The DRO is not as nice as yours Richard but it still does plenty of stuff and the whole package was a pretty good deal so I'm happy. You were right about the guys in Van... Very good to deal with and made the whole buying experience enjoyable(no pressure). I think "the wife to be" even had a good time ![]() Reg |
#214
I had a little time to play yesterday so I decided to take the 300 and the Euclid out and fill a hole in our lawn. It was pretty fun! I wish there was someone nearby to join in though because it gets boring by myself!
....someone should have checked the air pressure in the Euc's tires... http://youtu.be/NUbQ7bzsER0 http://youtu.be/wKFfceeIh8I http://youtu.be/MWIi1y4Af_E Reg |
#215
amazing...!!! looks so close to a real excav...your move is somewhat so perfect...so smooth and i'm yet to master this.... congrate to you for such a wonderful build, thx for sharing.
#216
looks like you could've used the mack too
#217
![]() ![]() Reg |
#218
I have been out of the loop for a time Reg, ( that work thing getting in the way )
WOW ! you have got it in high gear now ! GREAT model building skill, you have hit the big legue now with those builds and scratching all but the pump.. Very cool... Great videos' Greg |
#219
#220
I made a couple new vids today... and tried some different camera mounts. http://youtu.be/5mpcgUn0xAg http://youtu.be/SPUx7e3zrwY ...I like the second one.
Thanks for lookin! Reg |
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
