#161
Re: Classy Shak
Have a look at this picture for demensions of the motor
Everything which is round rolls well, I´m round... ...so kepp on rolling, keep on trucking!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Greets from Germany Martin |
#162
Re: Classy Shak
You would have to ask Lynn (tc1cat) what servo he used. as for the dimensions, the engine is 1/12 scale so it is just a little bigger but so close to perfect. to get it to set in the truck properly you either have to mod the frame rails or the oil filters on the motor.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
#163
Re: Classy Shak
Thanks guys! I found a site with the measurements. Needed to know if I could fit it under a globe cab (obviously with a few mods)
#164
Re: Classy Shak
Outstanding build Mike you have a lot of time in your build and you detail is a work of art cant wait to see it finished.
Becky
Member of the Central Plains Mini Truckers And the woman that makes the Cowboy who he is. |
#165
Re: Classy Shak
WOW thanks Becky, I'm truly honored that you took the time to say something about my build. You don't post much on the forum and to post on my build... Thanks.
#166
Re: Classy Shak
Lovin your biuld pure craftsmanship Are you still going with the white/purple paint
Dave |
#167
Re: Classy Shak
Yes Dave still white and purple.
#168
Re: Classy Shak
Hello Mike, I just wanted to say I can't wait to see this bad boy finished. It will truely be one of a kind.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#169
Re: Classy Shak
Hi All, Well I got my spiked lug nuts from Steve the other day and got them all polished up and installed. I have to say they look EXACTLY like what I wanted.
Thanks again Steve for making these happen. Here is a link to a video on how I polished these. I simply put a 2mm screw in my drill press, then screwed on a lug nut using the slowest speed. Then I got a cotton buffing pad for my Dremel, and used some green Jewelers Rouge.
#170
Re: Classy Shak
Those look AMAZING! That just makes the wheels pop - very nice.
Michael also known as "The Crimson Corsair" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#171
Re: Classy Shak
Those are coolMike..........Steve did a great job.
I wish you had the time to just work on this truck and nothing else. I'm ready to see this thing done.It's going to be an epic build
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#172
Re: Classy Shak
don't thank me I'm just the messenger on these My helper did all the werk on them . I'm glad you got the patients to put them on all 6 I got some to mount on before I ship they're wheels
#173
Re: Classy Shak
Mental! They really are a nice touch. Thanks for the vid on how you polished them. Simple and effective. Thumbs up!
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#174
Re: Classy Shak
Steve the Bi@#h part on the drives is you have to back the screws all the way out till they are flush with the rim and then get them to thread immediately in order for them to be tight when the lug is tight. I'm thinking about drilling the hub out one one of them so that the lug passes threw and see if that makes it easier, just not sure I want to do that..
#175
Re: Classy Shak
Thanks, and no problem.
#176
Re: Classy Shak
Thanx for the video Mike...You make it look simple. And I can't wait to get my wheels and the spikes. Look's real sharp, no punt attended.
#177
Re: Classy Shak
Hey Gents
I actually did some work on the Shak today... I figured out a way to run the fifth wheel lock and have all the linkage under the deck plate. I made a sort of bell crank. Now I will be able to have the servo in the sleeper and no linkage seen. I also built a functional release handle just like the real ones, so I will be able to unlock it either way. I do have one question though, I'm sure Paul, Nate, or any number of you can answer this for me. Is there a way to limit the travel of a servo or will it do it automatically. The reason I ask is cause the throw on the lock is only about 1/2" and if it goes to far past the limit either way it could move part of the linkage for the lock and make it so it won't work right. Anyway here are some pictures. The under side. I have made this by pinching the bottom part of the bell crank between two nuts because I have to have a way to remove the fifth wheel through the deck plate. This is the part that could turn if the servo moves to far. Here is the release handle. Now all I need is some ball joints and I got it made.. Does anyone know where to get some 2mm and 3mm all thread rods?
#178
Re: Classy Shak
Hey Mike, good to see some more progress on the "Shack". As to answer a couple of your questions, the servo can be limited on throw by where you set your endpoints on the radio. The shorter arm on the servo too will only allow it to go so far as well.
As for the all thread you may try McMaster as I believe they have metric all thread in those sizes. Looking good and can't wait to see more. Tyler
~Tyler~
RockSolidCustoms |
#179
Re: Classy Shak
Love this build Mike it is by far the best most detailed build of a semi I have ever seen.. Nice work man keep it up.
#180
Re: Classy Shak
Glad to see the Shak is Back Mike. Great idea with the dual function on the fifth wheel. The way I built my wife's truck I realize there is no way to run it manually
Thanks for posting and hope to see more Mario. |
