#61
that is a very nice knight hauler just redid mine also gonna post pic soon! funny i almost went with that same color shceme
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#62
your body work is great.all the corners and rounded parts or spot on. great job!!!!!!!!!!
Specializing in VW beetle water pumps! RIP FREDDYGEARDRIVE |
#63
Thanks Aaron, But you posted alot of them already, thanks. Right now I'm having major issues downloading and uploading so theres not alot I could do with them. I need some of that Hi-speed Comcast internet.
![]() ![]() ![]() ![]() ![]() Quote:
W900 when I was a youngster, my daughters favorite color on a vehicle is blue so I thought I'd give it a try again. Quote:
#64
Well I finally got it back on the table. Took it all back apart to paint the chassis and continue working on the lift axle.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More to come, Thanks for looking! |
#65
Chassis looks great!! Love that color of Blue! I bet that color really looks good out in the sun!! Cant wait to see more progress!! What did you use for your lift axle?
#66
Nice tri axle. I really like that blue. Thats a sweet lift axle! Can't wait for more updates.
One is too many and a million is not enough. Fred. |
#67
Thanks Aaron, the chassis will get another coat of blue and a coat of clear. The lift axle is a trailer axle that I cut the center out of just inboard of the inner most bearings/bushings. The center was replaced with 2 pieces of brass tube which the trailer axle sections slide into. I formed a u shaped piece of brass and soldered between the tubes. Then I formed a truss out of brass and soldered it across the top of the u and the tubes. Covered the rough edges with a little filler and primed it. I need to clean it up a bit and top coat it.
#68
Thanks Plow Jockey, the paint is Rustoleum Metalic Colbalt Blue.
#69
Well the Knight Krawler has all its own electronics now so I can put my crawler back together
![]() ![]() I got the lift axle finished and operating, eventually I will put a digital servo in it so I can program it to get a more prototypical lift speed. Right now its a Hitec MG 645, If anybody knows how I can slow it down I'd appreciate the info, I'm using a aux switch on an AirTronics RDS8000. http://www.youtube.com/watch?v=PUpyghe-nXo I got the HPI 7:1 GRU and 55T motor mounted and the shift linkage adjusted. Still have a few thing to do before I test run the chassis. Enough typing here's a bunch of pictures. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking Kent |
#70
You have come a long way on this.
![]() ![]() ![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#71
Sweet set up, I cant wait to see this baby all together.
#72
The chassis looks fantastic.
Does the lift axle have any suspension movement to it in the down position, or is it solid? I was just thinking if it is, you may have problems with bumps takiing the weight off of the drive axles and causing you to get stuck? I know in real life the lift axles are raised in rough terrain to prevent this, I just didnt know if yours was so solidly mounted to the servo that it may cause problems on relatively small bumps. |
#73
Looking good Kent. The chassis sure looks nice with that paint on it! Is that an aluminum transmission case, or the stock one painted silver? That's a nice touch. A little bling to constrast the paint.
Nathan |
#74
Hi BRICKNICK, I'd like to see it done too but I keep coming up with little things to add to it which sets final assembly back not to mention final paint which I need at least 50 deg. to do. One of these days! Quote:
![]() ![]() Quote:
Thanks for looking and the comments everybody! |
#75
Hi Kent,
Looking good, to answer your question about lift speed, here in the UK you can buy servo slowers that fit between the receiver and servo, I have used one from here before http://www.fast-lad.co.uk/store/prod...oducts_id=9380 |
#76
Hi Michael,
Thanks for the link I think I'll have to give that a try! I tried to do some paint work and it didn't turn out. Looks like I'll have to redo the cab, probably go with a single color. |
#77
Hey Ken, this is a very sharp looking build.....i really like that lift axle setup, care to elaborate on the build technique?
![]() I have used this servo-slower and it works really good (4-7v) http://search2.hobby-lobby.com/psear...low+down+modul
#78
#79
#80
Not a problem, pictures are always more fun than reading!
