Old 08-19-2013, 04:33 PM
Default Re: Movie Optimus Prime build
evergreen styrene has some sidewalk or square tile pattern sheets that might work, it would be a pain to get them chrome, but it's a start. maybe paul's chrome could do something with them.
edit: even better:
decorative stainless steel sheets , pattern might be a bit big, but i think they do custom orders.
http://www.quickshipmetals.com/decor...ess-steel.html
here's another place:
https://www.stainlesssupply.com/orde...line/index.php
Old 08-19-2013, 05:35 PM
Lightbulb Re: Movie Optimus Prime build
Bob, if you're using real aluminum doors, you could use an engraving tool to etch the pattern into the doors and then have the doors chrome dipped. It's a thought.
- RCT
WCMT Director -
Old 08-20-2013, 12:07 AM
kingbob kingbob is offline
Ive seen the square pattern styrene, and thats my fallback if I cant make anything else. I may get a better result by using a thicker piece of aluminium, the one I did above is super thin 0.1mm. A thicker piece may hold the pattern better. I have some 0.2 and some 0.4, so might at least try it.
That stainless above has a 3" pattern so is way too big, but embossing it over wire mesh might work.
Old 08-20-2013, 01:15 AM
Its not a layer issue though, just one of pattern.
Old 08-21-2013, 12:42 AM
Ahh, right, sorry didnt get what you meant. The Ali I used was 0.1mm, so almost like foil anyway. Im going to try it on a slightly thicker piece and see if it holds better.
Also just found some nice little 1.8mm LEDs for the trailer lights. Should be able to just have the round tip showing through on the outside.
Old 08-21-2013, 01:18 AM
Thumbs up Re: Movie Optimus Prime build
Nice find
- RCT
WCMT Director -
Old 08-21-2013, 03:03 AM
Not bad for 25c each!
Old 08-21-2013, 03:29 AM
Where did you get them from?
I know of a couple places (maybe), but not sure of prices.
- RCT
WCMT Director -
Old 08-21-2013, 04:22 AM
From an aussie shop online. Www.ledsales.com.au
They do some nice electroluminescent wire too, might have to think of a project to use some on.
Old 08-21-2013, 05:30 PM
bowtiebuba350's Avatar
bowtiebuba350 bowtiebuba350 is offline
bowtiebuba350 is on a distinguished road
I love this build
Old 09-17-2013, 07:55 AM
OK, work has kept me busy recently, but i have 2 weeks off now, so am at it again!
On the plus side, the clearcoat i put on the body has had time to cure, so i set at masking up the front end today.
And finally, success!
I'll give the front end flames a day or 2 to dry, then start masking up the cab doors and roof. Then just the sleeper to do.
Old 09-17-2013, 09:34 AM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
looking great bob
Old 09-17-2013, 11:35 AM
That looks really nice, Bob! Can't wait to see more. Glad it turned out well for you this time. Finally, right? Take a deep breath, relax, and soak it all in. Well deserved.
Old 09-17-2013, 12:33 PM
Finster's Avatar
Finster Finster is offline
Nice paint job, well done! Looking forward to seeing it finished as I'm sure you are to
Brian
Old 09-18-2013, 11:31 AM
OK, after HOURS of cutting tape, the body is masked and ready for painting blue tomorrow!
Fingers crossed i dont screw this up otherwise the body is going through a wall! lol
Old 09-19-2013, 12:49 AM
FINALLY!!!!!!!
So freakin happy the body is finally painted! And its mostly to my satisfaction!
I printed out pics of the real truck, and traced the flames onto tape, so the design should be as close as i can get in this scale.
I would have liked the red/orange fade on the hood to be smoother, not so rapid, and the finish in a few places isnt as smooth as i'd like. BUT, it is finally done! Now i see it painted like this i realise there really was no way to do the tiny pin stripe around the flames. In scale its just not practical.
Still needs a clear gloss one the blue is cured, but as near as i can tell, paint is complete! A huge milestone as far as i'm concerned!
I'll get a few better pics once the sun comes out of hiding, and the body is a bit drier and safer to handle. So just a quick snap for now in bad light!
Thoughts?
Old 09-19-2013, 03:02 AM
Ahh the sun came out. Here we go, some decent pics
I like it
Old 09-19-2013, 03:06 AM
The only real hiccup is at the top of the front flame on the left of the sleeper. I didnt quite do enough red, so it shows a little bit silver.
Hopefully that will be obscured by the exhaust shield once fitted.
Old 09-19-2013, 06:06 AM
looking good out in the sun
Old 09-20-2013, 05:00 AM
You'd think i'd have learnt this build is best served by patience, but apparently not.
Last night before bed i threw a quick coat of clear over the body to protect it all. Looked this morning and it made some of the blue on the sleeper run! *bangs head on wall*
The flames at the front are fine, they had a full day extra to cure, but the sleeper had only had a day. This is the only really bad bit. I should be able to spray a bit of blue over it to blend it in and hopefully save it.
Just should have left it for a week or so to cure.
(we need a headbutting a wall emoticon!)
The other side is mostly fine. Little bit of the blue collected in seams and against raised detail, but most gets hidden.
I started adding adhesive chrome metal foil to the appropriate details. I decided to use this instead of the folded metal rod i made as i tested it on a scrap piece of plastic and couldnt glue it in without wrecking the paint.
Need to make door handles and the vent for the sleeper doors, hopefully done today/tonight. Then can start bolting on details!
