#121
Thanks all.
Joe, I can't remember what sizes the cables are. I've been experimenting with 3/64'' , 1/16'', & 3/32'' 7x19 to see how flexible they are. But to be scale the drag (2'')=1/8'', hoist (1.5'')=3/32, boom ropes and bucket dump (1'')=1/16'' |
#122
Got some more progress this week. There's a lot of tiny details unforeseen here. Still need some splice plates.
#123
Looking really good! Work faster! Wanna see more!
#124
10% inspiration 90% perspiration
#125
Looking better and better
Jeff |
#126
That boom will be incredible when done!
#127
I've been working hard on the slice part of the first section still. Came across a small problem where the side, top and bottom diagonals attach in the seam area but figured out a fix because soldering a bracket on isn't strong enough. If I was working in steel I could just tig weld it on. I probably could tig the brass but don't want to chance ruining a tee chord and a few hours machining a new one. I don't have any pictures yet.
#128
Steve-I think a silver solder joint is about as good as a weld when done correctly but I'm sure you have this situation covered. Let us see pics whenever you can.
#129
Here you go Tom. This is what I was talking about. I made these angle pieces that bolt on rather than just be butt welded on. The wall thickness is .020'' at the thin area. On the top view I don't have the 1/4'' tube milled yet,that's just one of the lattice pieces,also at that point there's two 5/32 angles back to back only one shown. Maybe by next week I'll have most of this area built I hope sooner.
Milling the profile before drilling holes ![]() End view of all 8pcs to be cut in half ![]() ![]() Top view ![]() |
#130
awsome work!!!!!!!!!!!!!! more pics please
#131
Now I see- this sure looks complicated! Looks like a "whole lotta thinkin" going on here.
#132
Excellent nice machine work but very expensive with all that brass. Ed
#133
Got some progress from all the thinking going on. It sure is nice to see how the pieces are coming together after several hours of machining and procrastinating.
I did a count of tubes that need milled for the top and bottom surface still and there's 44. ![]() ![]() ![]() ![]() ![]() |
#134
Looks really good steve!! Have you counted how many bolts will be in just the boom?
#135
HMM. Probably around 700? I do know there will be 76 at each splice.
#136
Wow. 9W Monighan, I remember your post from Scale 4x4, and replied a few times there, but now that I've actually caught up with your build over here, all I can say is this project is truly a labor of love. I loved looking at all the photos of the machining, in process. This is truly an epic build. I am in awe of your skills and talents.
Nathan |
#137
Thanks,Nathen.
I spent most of the weekend working on the boom but only made 8 pcs. and half of 8 more tubes. Too many distractions updating the drawings. There's still about 36 more to go on this section. Sorry no pictures today. I probably could have gotten more done if I didn't have to sit on my porch giving out Halloween candy ![]() I'm almost to a point where I can solder some of it together. |
#138
Anytning going on?
#139
Haven't done anything this week but drive to Baltimore,MD. and then up to Youngstown,Ohio to deliver a job and pick up a load of steel bar for my real job. While on the way home from MD. I wanted to stop at Dragline World to see Jim but I didn't have time. I hope to pickup where I left off Sunday on the boom but first I want to work on another paying job I've been fiddling around with this week. "Both regular and side work are once again getting in my way"
#140
A little time this evening so I made some more tubes.
![]() ![]() This is were the bottom section breaks apart. ![]() |
Currently Active Users Viewing This Thread: 20 (0 members and 20 guests) | |
