RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more |
#81
great truck, nice color great dump system
#82
Thanks cosworth.
I took the cab back off to make an adjustment to the esc so I thought I would snap a picture of the electronics. I mounted the power switch in the drivers side "battery box" so it is nicely hidden and raised the height of the cab a little to give it a better stance. The higher cab height also allowed me too put the battery under the hood. I am running a Sabertooth 2x12 for the truck and box dump so the wiring is really simple. ![]() ![]() ![]() ![]() |
#83
I have the power switch in my KH dump the same way.
![]() What's the electrical device attached to the cab rear wall?
#84
Nice and neat, I like it!
Stu |
#85
External BEC would be my guess as well. I see a red and black (power) wire going in, and a servo type lead (red and black) going out, to what looks like the receiver.
Very nice job with this build Reg. Are you going to do some more 1/14 scale trucks now?
Nathan |
#86
You guys were having fun guessing what that is hey? You all were right, it's just a cheap BEC that I had in my pile. The drawback to the Sabertooth esc is it only provides a 1 amp BEC. This truck has some cheap Towerpro metal gear servos in it that are really power hungry and without the external BEC it goes into protection mode when you steer and shift at the same time. I think if I switched to higher quality servos I could probably go without it but this was a quick fix.
Nate, I am not sure if I will start building anything in this scale or not. I am considering selling this truck and if I did then I would buy another one but I really doubt I will have a 1/14 fleet anytime soon. I took the truck outside for the first time today and drove it around. I have to say that I wasn't all that impressed with it after being used to stuff that is so much bigger and heavier. I guess if I locked the rear diff and geared it down I would like it more. I also think it would make a huge difference if I had an inside place to play. My 1/10 stuff is too HUGE for cruising in the house/shop whereas the 1/14 is no problem. Never say never though! ![]() |
#87
Man great work as always on this thing. I think my yarder will look better with 1/14 trucks because styrene at 1/10 is kind of outrageous. Some day ill have an actual job out of college and get get into alum.
Jarrett |
#88
WOW, awesome build!! Amazing work.
John |
#89
Rcp your truck looks great, I think you've got a best seller on your hands here. Can't wait to see your vendors section
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
#90
![]() ![]() I am looking forward to the vendors section as well and I hope it is a success. I think it would be really cool to see other people get enjoyment out of stuff that I have made...and of course I would enjoy their money... ![]() |
#91
#92
#93
#94
Haha, Yeah you're stealing fish from my kind
![]() ![]() I'm happy to hear that someone else on here makes their living from the ocean though! |
#95
I have been taking this truck apart and putting it back together in order to test every box that I make so I needed to come up with a faster way to disconnect the wiring on the dump drive motor. I had a couple of small bus-bars in my junk so I hooked one up. I made a couple of quick mods to the truck side of the box pivot where it bolts to the frame and mounted the bus-bar between a brace and the rear bumper. I also drilled holes in the cross members so that I could feed the wire though them up to the cab. Now I can leave the wires hooked up to the esc and remove a short pigtail from the bus-bar to the screwdrive. Sometime in the near future I will pick up a stock set of KH rails so that I can set up a jig but for now this will help.
![]() ![]() ![]() Thanks for looking! |
#96
#97
Looks cool, how much is this going for?
#98
I'm not to sure yet because there is still a fair bit of work to do but I am trying to keep it under $250. My plan is to mount this to the frame with the fifth wheel still attached. That way, anyone with a day cab truck could swap it off and tow a trailer.
Reg |
#99
I worked on this for a bit this morning but snuck away to spend the afternoon riding my ATV and walking around logging slashes in order to find a Xmas tree(one of my favorite jobs to do for the holiday season
![]() ![]() I machined up some frame braces, arranged them so that they clear the fifth wheel and welded them in place. I still have to fasten it to the frame but it won't need much because the braces hold it side to side and fore and aft. Let me know what you think! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking! |
#100
Hi Reg just after I finish my flat bed someone (you) comes out with one looks good . Mike
