#581
RCLogger-nice looking work area!!
#582
Hi Greg , how was the show ?
Thats my idea of what a sandbox should look like : ) |
#583
#584
#585
#586
RCLogger
Way back on page 3 or 4 of this thread you mention you get your #35 chain with K1 links of of China. From whom do you buy if from/through? I may have missed it but, I don't see that mentioned anywhere. Alan |
#587
Cheer's, Neil. Last edited by doodlebug; 11-19-2013 at 10:10 PM. |
#588
Now I know what to search for I found this http://www.royalsupply.com/store/pc/...m#.UowrzXy9KSM Seems kinda pricey though Alan Last edited by A.ash; 11-19-2013 at 10:27 PM. Reason: Added more comments |
#589
$13.00/ft is the price to beat for#40 k1 chain.
I haven't had a chance to price it at applied industrial technologies yet. Cheers, Neil. |
#590
Sorry guys, I didn't catch that you were looking for chain. Here is where I get it, they brought in a bunch...
http://www.vikingchains.com/ |
#591
Thanks!!! I will check them out.
Cheers, Neil. |
#592
love your setup.. I like watching your vids on youtube
#593
I love this chain Idea and my yarder will need tracks sooner or later
Jarrett |
#594
love your models. I am building dozer my self using a lot of your great ideas. can you explain how you have your wiring system wired up. how do you have the 18 and 12 volt batteries hooked up to receiver with a 6v rx battery. can you have more than one speed control going into the receiver suppling it power?
#595
Max power to the RX is 6 volts Sabertooth speed control can take 12 / 18 volts : ( to RX ) Hyd pump 12 volts : ( can be turned on/off with a servo or speed control ) Hope this helps greg |
#596
I guess what I was wondering is can you plug two speed controls into one receiver when speed control has a batterie hooked to it. Does it not bring power to the receiver from each speed control?
#597
If you want to hook two speed controllers with separate batteries to one receiver you must take the red wire out of one of the controller's receiver plug. Very carefully remove it by releasing the brass prong out of the plug with a straight pin. I just put shrink tubing over it so it doesn't short out on anything and you're good. If it's a Sabertooth pull the Red wire on both plugs to the receiver. Now if it's one battery feeding both speed controllers, it really doesn't matter as it's the same power source.
Rob |
#598
That was my concern. So when using a receiver pack. Remove red wire from both speed controllers. Sorry just don't want to burn out my receiver. Whst kind of run time are you getting with your set up? Thanks Patrick.
#599
Yes your right. When you use a separate battery pack for the receiver, you pull the Red wire from both speed controllers. You'll have to ask Greg about the run times as he used to run Nicad's but has now switched to Lipo's.
Rob |
#600
Thanks that helps a lot.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
