Old 01-05-2014, 06:17 PM
Default Re: 777 HAUL TRUCK (1/12 size)
Originally Posted by DADSGARAGE View Post
I take it you are suprised at the weight....LOL...told you it was heavy!!!!
( when it is finished I will get the actual weight...I'm only guessing on the weight being 85-90lbs...but my back tells me I'm close!!! )
The weight on the 1:1 777D is 142,573 lbs so if I did the math right the 1/12 model should be 82.5 lbs ??? So it may end up being a bit heavier than it should be in terms of scale....good thing this is a 1/12"ish" size and not 1/12 scale...LOL....
I am surprised how heavy it is, or will be, but then again it is a big model! Seeing it sitting on your lift table really helps put it into perspective for me, since we have many of the same sized lift table all around work.
At least you might be the first to say even the weight was accurately scaled down!
