  #38
Old 04-05-2014, 08:41 PM
Lmackattack's Avatar
Default Re: Full frame Dump trailer build ?
Yes I was scared to pick it up expecting to see gray primer on the fenders and sleeper. it did knock the lens out of the turn signal but I did not haveit glued in.foundit and put a dab of ca glue to it and all was good......when I got home I did a little tinkering on the trailer and I noticed that the passenger side arm is pushing harder than the driver side. a little adjustment and It seams to lift a load more stable. the springs are still an issue as as soon as it leans to one side it does not want to come back to center. with a full load the forward trailer axel rests on the bottom of the frame. as soon as it leans its to much weight for the springs to fight. I have some extra leafs im going to try first and if that don't help I will put beams in.
