Old 04-22-2014, 05:03 PM
calum_scania's Avatar
Default Re: Liebherr 922
Thank you guys!
This is my first hydraulic machine, i'm slowly ordering up new parts to improve the way it performs and looks
Can anyone advise on my hydraulic pump? I'm looking to upgrade it to speed the movements up..
Old 04-23-2014, 02:38 PM
MoRockN's Avatar
MoRockN MoRockN is offline
MoRockN is on a distinguished road
Originally Posted by calum_scania View Post
Thank you guys!
If you wanna keep the same pump, you can change it to brushless motor from Leimbach and that will make it more smooth. You also can up the bars ( or psi ) on the pump and that will make it seem faster ( I think 18bar is max ), but that also puts tons of wear on the components. If you want a new pump you can use a JUNG setup if you can find one, only thing is you have to change the layout and I'm not sure you can fit all of it on there. I have the same pump on my 944 and it's awesome. There are more powerful pumps out there but only fit larger machines with more space.
If you got it, a Trucker brought it....
Old 04-23-2014, 04:36 PM
Currently in the process of buying a Martin Kampfshoff pump which i believe has a jung motor fitted.
If it wears out the cylinders or valves i will just upgrade them to better spec items
I am also looking for a pressure gauge and fittings in the UK?
Calum
