Old 04-25-2014, 12:43 AM
avel avel is offline
Default Re: LR634 is HERE!!!!! Tracked loader
OK, anyone NOT use pliers to slide the locking sleeve over the hydraulic hose?
I used some made for putting loops in wire, sold in the jewelry/bead aisle. I tried with my fingers, and some cloth but all that happened is I pulled the skin back under my thumb and started bleeding. I even had boiling hot water to help soften the hose enough to slide over the nipple.
todays update
Installed the thicker hoses between the pump, filter, and control valves. Centered the servos and installed them too. I want to finish this tomorrow so I can play!
Any tips for cleaning up hydraulic fluid?
