Old 04-30-2014, 12:08 PM
Default Re: Wedico 966G VS. Carson LR 634?
Leimbach provides their own special brushless motor that mates with their pump, it's what the Carson is using.
I'm not sure what the bore difference is in cyls between the two models and most small models today are using 2mm ID plumbing, where as some of the early wdc (or maybe still is) is using 1.5mm hose & fittings... it's not the pump, it's the plumbing size that determines the speed of hyd functions.
