Old 06-03-2014, 08:39 AM
gismow's Avatar
gismow gismow is offline
gismow is on a distinguished road
Default Re: Rebuild of a Knight Hauler after a Crash
Hi
Just a small update. The position of the stear servo wasn't as expected. In the past I only created a temporary solution with an ugly PS plate. Now I wanted a solution that hides the servo between the frames.
So I two holders of brass with a threaded pin soldered in to fasten the servo. The frame got 4 holes and the holders fitting screw threads.
Done...
In the meantime I started to paint the cabine. It's nearly finished, only the clear coat layeers must be sprayed.
Greetinx
Peter
