Old 06-17-2014, 06:37 AM
JohnStilwell's Avatar
JohnStilwell JohnStilwell is offline
JohnStilwell is on a distinguished road
Default Re: Mack and Pup
Thanks for the compliments!
The tires, front and rear, are from RC4WD: http://store.rc4wd.com/Road-Trucker-...es_p_3059.html
http://store.rc4wd.com/Roady-Super-W...es_p_1785.html
I was limited in tire selection because of the six wheel drive, they all need to be same diameter.
The spray tank is almost done, powder coated it Sunday, got the filler neck and cap yesturday, just need some gasket material for the lid and the plastic for the fill window.
It's really heavy and glad I added extra leafs to the spring packs. I need to weight the truck and then the truck with the tank. (tank is 2 gallons), so that will add another 16 lbs when it's filled.
I might need to get the metal helical transmission gears I've seen at RCBMIN or WTBCAR.
John
