Old 06-27-2014, 12:21 PM
Default Re: Volvo A40F
Originally Posted by RCP57 View Post
Very interesting start Ari with those planetary gears! What axles are you using and what is the overall width with the planetaries installed?
Thanks, Reg
I decided to start with the axles to see if it's possible to add those planetary gears to these axles.
The width I'm aiming is 192 mm hub to hub.
It needs several parts to attached the planetaries to axles. Also the bolt pattern on planetaries don't match with the rims I'm using, so I had to make a new hubs over them.
Here are the parts for one side:
