  #28
Old 07-01-2014, 11:44 PM
Default Re: Another Tigercat...
I got a few of the kinks out on the skidder today(literally). It turned out that the issue with the blade was a kinked hose so I shortened it up and that solved the problem. The valve block was weeping a bit so I took it apart and put a thin strip of loctite around each rotor and buttoned it back up. No leaks there now. The grapple cylinder was binding mid stroke and causing it to leak. I made a bit of a relief near the swivel and now it only leaks once and a while. Once I did all this and finished the wiring, I decided to have a little playtime. I'm now running most of my models off of one radio so I need to remember to center all the switches between models! Oh well, hopefully I will get it all figured out one day...
https://www.youtube.com/watch?v=3e5H...tJ-DusnO8Onw7A
https://www.youtube.com/watch?v=4Oic...tJ-DusnO8Onw7A
https://www.youtube.com/watch?v=Oc8A...tJ-DusnO8Onw7A
