Old 07-05-2014, 09:30 PM
BRICKNICK's Avatar
BRICKNICK BRICKNICK is offline
BRICKNICK is on a distinguished road
Default Re: windowless AC units
Originally Posted by scalelover View Post
They also make mobile a/c units basically like the plug in radiator style heaters. I've got one at my shop, and I've seen them in both 110 and 220 in multiple sizes. I believe Home Depot sells two or three diff styles. If you can't find anything LMK I'll look up the info on the one I have.
--Dan
I had one in my old apartment n it kicked butt, it would freeze out the entire apartment. I just had to put a few fans in to get the air around corners n in the bedrooms. The unit stands inside n you run an exhaust duct hose outside. The only crappy part is you need to drain the condensation out of the bottom of the unit where it has a drain plug n a pan.
