Old 09-08-2014, 09:16 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Ny-Lint Mobile Dragline Conversion
Now that it seems to be working pretty good, time to finish up.
Added studs to the end of the drums and supported with channel that will be attached to the inside of the cab on the off side to support the drums/servos.
Also turned a bit off the outside diameter of the to large drums and left a small high spot on the inside to reduce the friction on the angle support bracket.
Jim
