Old 10-23-2014, 04:28 PM
apfubar apfubar is offline
Default Re: DX10 or MC20
Yes the mc32 has more channels, and a couple more controls as well(3 sliders in between the sticks). Fwiw I think I needed 14 channels for the 944, due to the split boom, two aux hydraulic ports, and lights. On the HOTT stuff you can get a multiswitch module which allows 1 channel to control 4/8 functions(reduced resolution, and response... Good for secondary functions)... Which might eliminate the need to go beyond the mc20.
I think other radios have similar functions to the model match...
Jeti may have model match...
with Graupner hott, you have to turn the model off, select a new model in the tx, turn the new model on... So you can still run two models, just a little bit more involved to switch between them.
It's not a huge problem for me as I run the excavator on the MC32 and the rest of the gear on spektrum.
If I ever get a second excavator, I will use the mc32, and accept the pain... I wouldn't be switching that much between the two machines...
Cheers,
AP
