Thanks guys, its back together:
![]() Made a couple of vids, testing out the pump with it bolted down to the base plate, after 1.30 mins its un-bolted sitting on a piece of foam rubber. Pump test First attempt at digging ![]() Digging I have 2 return lines back to the tank, 1 goes through the prv, which one should I put the filter in? I will look for some hlp-25, on a french forum they are suggesting ATF, I thought that would damage the seals? Cheers Stu |
