Old 12-09-2014, 09:14 PM
Supermario's Avatar
Default Re: S&M construction open for bizz nizz!
Originally Posted by Bo Wallen View Post
I wonder if this could help a little ? It,s cheap http://www.globalindustrial.com/p/mo...B&gclsrc=aw.ds
Thanks for the link Bo. I notice the minimum drum diameter they recommend is 3" and that's probably due to the staples that keep it together can't make a tight radius.And that's for a commercial use , for what I'm doing this might work? I might have to enquire further. Thanks again
Mario
Old 12-09-2014, 09:24 PM
woodhog's Avatar
woodhog woodhog is offline
Hey Mario, Izzy had a belt made for my belt trailer that is continuous and is vulcanized so it doesn't have a seam and its a real nice . Give him a holler it will work perfect and can be made any length
Woodhog
Old 12-11-2014, 09:57 PM
Supermario's Avatar
Thanks for the info Chris . i haven't talked to Izzy since he built our tri axle end dump trailer. Only seems appropriate to ask him for help building something to load his trailer
In the meantime I got a chance to start cutting this tire tube. I cut the valve stem out and trimmed the stem layer down and now can use the inner circumference for a belt. It's a little shorter than 4ft but will work great to test things out.
First cut to make things easier to handle...
its 4" wide now as I followed the centreline visible mold lines. Final cut next I think will be 2 3/4.
As you can see by the smiley face strip you don't have to go very far off centreline and things get unusable.
