Old 01-23-2015, 05:31 AM
Snowman3725
Guest
Posts: n/a
Default Re: led lights
The MFU has a couple aux outputs. Easiest way would be to find an extra lighting harness, headlight, tail light etc, cut the LED off the end and solder the wire leads from your new under can lights to the cut harness with the plug on it and plug it in. You could also get a TLU-01, which is designed for running extra leds. It plugs right into the MFC and has 8 plugs to run lights. Only problem with that is its "constant on" meaning it's not controlled by your remote, instead it runs inline with your battery and has an on off switch.
