Old 02-08-2015, 04:19 PM
Default Re: Liebherr 574
Originally Posted by Supermario View Post
I'm confused? My loader clears the box with no ramp at all. With full up and bucket dumped I can still just clear the box edge. I've got no cheater boards on my truck but surprised to see you need such a ramp.
It must be my hyd cylinders have more range than the firgelli actuators ?
Yes, I believe yours lifts a bit higher than mine. It will load my KH OK with no side boards but the Hayes box is quite a bit taller. The truck itself is also taller by almost 1/4" because of the reworked suspension. The way I have the actuators mounted is great for power but not for stroke. It won't sit the bucket flat on the ground either but I was determined not to cut the loader anymore than necessary. I definitely don't need to have that large of a ramp but it was built for something else and does the trick temporarily.
