Old 12-05-2010, 04:23 PM
mog mog is offline
mog is on a distinguished road
Default Re: mog's trucks
well got a little work done on both trucks. was trying to fab up a frount bumber like this but i think i missed the mark anyone got a good idea to make the 90 bends on the pipe i try using soft copper and bending it with a brake line bender but it deform's and needs to be a smaller 90.
got stared on the boom for the picker truck it going to be way heavy too heavy i think might have to rethink the boom. but this is what i got so faw. the boom is made from .062 steel. i would like to stay away from AL likes to gull really eazy and the heat that it takes to weld would have it worp for shere. did manige to get the plow truck out for a little work too.
http://www.youtube.com/watch?v=ZLtvJQpPvcE
some lights for night plowing http://www.youtube.com/watch?v=dZxZJCPXNjQ
Old 12-05-2010, 04:37 PM
Dreamweaver's Avatar
Weaver Of Dreams
What you could try, Home Depot has a tubing bending set. these look like tightly wound springs that are flared out on one end. I found them in the tubing are in the plumbing section. I think they go from 1/4" tubing up. Anyway you slide the tube in the spring and then bend it and the spring will not allow the tube to distort. Then the hard part is getting the tube out, you just have to twist the spring off the tube.
I would try these you should be able to get the radius you want. Also try the soft copper tubing they have I think the biggest they come in is 3/8" but the stuff is soft and pliable, it comes in rolls. It's is the stuff that you would use for like the Ice maker on a fridge or to run water to the swamp cooler (if your from a part of the country where they have swamp coolers
-Mike
Mike "DREAMWEAVER" Johnson
