Old 11-23-2015, 09:55 AM
Default Re: PC1800 Front Shovel (1/12)
Since I'm a Komatsu guy, I've been waiting for this build to start. Great work on the swing bearing! Don't know if it will be a problem, but sometimes when a main relief valve is adjusted well-below its normal operating pressure, it is not very consistent or accurate. I'm guessing this system has an original pressure of 2500-3000 PSI, dropping to 250 PSI might be a problem. Hope it is not for you. Should you need additional technical information about the full-size PC1800, let me know. Be glad to assist.
