The fuel tank (which will hold the servo for the front axle differential) is up next.
![]() A spacer is provided to take care of the narrowing of the frame. ![]() ![]() The other tank support will to here. ![]() The instructions indicated to install M2x8 bolts with the heads on the outside of the frame. Bit of a fiddle and as there were 4 M2x5 philips screws included with the package I ended up using those to install the supports. Easier that way. ![]() I installed the fuel tank without the side covers for now. I tried the side covers for size and they were such a tight fit it was quite a hassle to get them back of. Also, since I am still waiting for the right front axle, I can't install the servo as of yet either. Will have to cut some holes in the tank to accommodate the bowden cable and the wiring of the servo. ![]() A look at the inside of the tank: ![]() And with the holder for the servos in place ![]() The tank straps are clipped in place (and I messed up and installed them wrong way up as I found out later) ![]() These 2 little bits are needed to attach the straps to the supports. ![]() A bit of bending involved. ![]() Tank strapped in. ![]() Had a bit of trouble getting the strap to clip into the provided space. ![]() Only after seeing these pictures I noticed why I had a bit of trouble ... Well will redo it tomorrow or so. ![]() ![]() A nice touch is that the provided gas cap in not it plastic as I expected but is machined out of aluminium!
Cheers, Stephan (Rakthi is the one in the avatar) Last edited by Rakthi; 11-28-2015 at 04:56 AM. |
Tags |
man tgx xl, scaleart, trailer |
