Old 12-28-2015, 10:00 PM
TRUCKMAKER's Avatar
Default Re: King Hauler driveshaft length?
Check out this thread for an inexpensive way of making your own shafts.
http://www.rctruckandconstruction.co...read.php?t=708
You can also adjust the drive cups on the axle and transmission so there is very little fore/aft play in the shaft when all tires are flat on the bench, then see what you get when you flex the suspension and readjust accordingly.
