Watch some of Bennett Shovels Lima 2400 videos. That machine has the same type as this B-E one. I think the reason for this type is because on these smaller machines the drag cable is whipping around way more than the giant dragline's ropes. Translating into more wear so the load is transferred into both sheaves. The large machines have more space to put larger diameter sheaves on turning slower lasting longer. |
Thanks i only saw it on the truck in a couple videos in a garage with a dirt pile. Killer looking crane.
That's a really slick roller fairlead. I would make a T plate adapter to mount that off the front so 3 fasteners or 2 fasteners and lifting a hook off a lip let you pull it to convert to clam. I don't think it would need to be offset above or below much since it looks like the larger sheaves are close enough the cable is captive between their edges. How much float do you think it'd take to keep the line smoothly filling the winch drums instead of bunching up? |
Friz,
This thread probably has more stuff related to my crane conversion. It is the crawler undercarriage that I made last fall. http://www.rctruckandconstruction.co...ad.php?t=10381 Jim |
Do you remember any details about the drag bucket, was it made off any plans or just eyeball? I assume its brass or steel?
Jeremy |
Jeremy,
It is all brass from the rack at the local farm store. I can get you some measurements if you want. The bottom is made from a pretty thick piece that was full width (1.5" I think) and I basically found a patent drawing of a bucket that I printed to a size that looked about right for the scale of the machine. Let me see if I can find the link that I used. One of the photos in the build has the print under the bucket in one shot. The video at 1:50 shows the drawing I used. I basically used the drawing to match the curve of the bottom piece. Still looking for the link, stand by... Okay, let's see if this link works... http://patentimages.storage.googleap...1/imgf0004.png And this should be the full document... http://www.google.com/patents/EP0321542B1?cl=en And mine measures .070" center base plate 2" wide at the mouth and I tapered it a bit toward the rear to make it load a bit better. The sides are about 1" tall and I made them from thinner .035" but they could have also been .070" to add weight to the bucket. I thought about adding wear bars to the under side of the bottom and maybe sides to give it more mass. Jim Last edited by Rvjimd; 02-15-2016 at 10:34 PM. |
Guys,
I'm trying to improve the crawler on my crane. I decided to try the "Z" style drive tumbler. My question, do the lower idlers help keep the tracks centered? Here is a pic of what I'm trying to do. Not sure what it is on? Old something? ![]() Anyone have any drawings of the idlers for something like this? Why are some like this and other like center wheel and knobs on the driver? Thanks, Jim |
Here is my prototype Z tumbler. Now I'm trying to figure out what to use for the new drive "stubs" or dogs or whatever they are called? The little nub on the track links. I need something a bit wider than the current version.
![]() Jim |
Yep. And I think the bottom rollers should be spaced different than the spacing of the lugs so the track can't slip around them. That way at least one or two rollers and lugs will always be engaged.
My guess is patents. Someone patents one style so the next guy has to figure out his own way. And always there's the quest for a better mousetrap. |
