Old 02-04-2016, 07:16 PM
Cooper's Avatar
Cooper Cooper is offline
Originally Posted by Mikem View Post
When you solder the cylinders together what solder do you use ? Mike
Just cheep stuff. Radio shack solder. But,,, I know from past experiences,, I should have brazed the end caps on first. Reason for that would be I could use regular solder on tubeing without the risk of other joints coming loose. As I did place some heat block (wet paper towels) around areas I didn't want to desolder. For me heating such small pieces it's pointless to use silver solder with a little higher melting point then using lesser solder on next parts. I got a big torch and I just end up going past the correct temp on areas I shouldn't. Another words , I don't really know what I'm doing
Currently Active Users Viewing This Thread: 25 (0 members and 25 guests)
