Been a while with an update ...partly because I've been without computer for 10 days but mostly because lack of time.
So after a 2 week wait the new servo for the rear diffs arrived. I filed off one of the attachment points and installed it. Hooked up the cables and found out out the servo isn't strong enough to lock both diffs and I ended up frying the servo. Totally my (stupid) error that. ![]() So ordered new servos again and decided that I would either only be able to lock one rear axle or I have to get one servo for each axle ... Took a good look at the frame and figured that just possibly I could manage to tuck the extra servo reasonably unobtrusive in the frame. In the servo kit from an 6x6 or 8x8 kipper I ordered extra, there was also this part: ![]() Which (with a bit of filing and cutting) would just be able to fit in this area next to the transfer case. ![]() To be able to attach it, some holes in the frame would need to be enlarged to fit M2 screws. This turned out to be more complicated than it sounds because I couldn't remove that one screw of the four that hold on the exhaust ... ![]() Thanks to Dremel, flexible attachments, strong language and a repaint of the fuel tank ... ![]() The primer in the above pic looks bad because it started raining just after I painted it and in the rush to get it inside I dropped the piece. ![]() So after sanding, a new coat of primer and the final coats of red, I installed it. Mounted one of the non-operational servos to see how it would look. (This servo would lock the 2nd rear axle) ![]() ![]() Will need to make a red cover for the servo, but that should be something that isn't too difficult (we hope) ![]() Also might have to do something about the run of the bowden cable of the first rear axle as they cross one another ![]() So now we have to wait for the replacement servos to arrive. After a lot of searching, I also succeeded in locating a couple of the Robbe FS 70 MG servos that ScaleART used to supply. Will see if those are less temperamental. I could go ahead and start the electronics compartment, but I rather wait until I have the servos so I can get the wires to run cleanly to the front. Something that will become less easy with the electronics compartment installed. So we wait again ...
Tags |
man tgx xl, scaleart, trailer |
