Old 03-31-2016, 10:14 AM
AbelVincze's Avatar
AbelVincze AbelVincze is offline
AbelVincze is on a distinguished road
Default Re: Volvo G990 Grader
Very nice tires Is there any information online, how they were produced?
Old 04-01-2016, 04:42 AM
Stefan Stefan is offline
Stefan is on a distinguished road
At least there used to be such information. However, it was written in German and, the last time I saw it, the picture links were dead. I'll try to find the article again.
Stefan
Old 06-12-2016, 12:50 PM
Sorry, I´ve only been able to locate this German posting on the tire making (see post #8). And you have to be registred
Old 06-12-2016, 03:17 PM
AbelVincze's Avatar
Thank you Stefan, i will check it!
Edit: for some reason, the link is not working for me.
Old 06-12-2016, 03:57 PM
Here (the colon was missing, I cannot edit. Maybe the Admin can correct it and delete this post?, thanks).
Stefan
Old 06-12-2016, 05:27 PM
AbelVincze's Avatar
Thanks, it works (just have to wait an admin for registration approval...)
Old 06-13-2016, 02:13 PM
Here is the continuation of post 218.
Setup for drilling and inside turning of the eyes:
Setup for making parallel the side faces:
Tapping M1.6:
Making the "covers":
Inserting igus iglidur bearings (flush cut after bottoming out):
Assembly:
It remains to shorten the necessary screws.
Thanks for looking,
Stefan
Old 06-13-2016, 02:46 PM
Sure you're not building a 1:1 grader? I'm not sure what I appreciate the most; your patience or handcrafting skills
Old 06-13-2016, 09:51 PM
jack van's Avatar
jack van jack van is offline
it is very very nice work good on you a master at work
Old 06-15-2016, 02:59 PM
D8R D8R is offline
Stefan, you'r setting the bar very high now. Those details will make this grader stand out. As mentioned above, is this 1:1??
/Dan
Old 07-24-2016, 04:57 AM
Thank you Emil, Jack and Dan! Yeah, trying to keep it scale. 3D printing takes you a long way, but you still see the layers. Suppose some careful grinding could take care of that.
Now, machining of the lift cylinder arms has been almost completed. Just need to fill out some shrink holes (and grind out the layered structure ).
Drilled and reamed to 14 mm.
Bushing with a 12° conical hole for an indexing lock pin.
The indexing lock pin mechanism (still to be made) will be attached on the rear side of the plate with the "key hole".
Cheers!
Stefan
Old 07-24-2016, 09:50 AM
Amazing!
Old 07-24-2016, 01:51 PM
Northern Farmer's Avatar
Thumbs up Re: Volvo G990 Grader
Some serious fabricating skills you have my friend!
Old 07-26-2016, 03:28 PM
D8R D8R is offline
Piece of art!
Old 07-26-2016, 09:34 PM
jack van's Avatar
so i hope you have been makeing atleast 10 of each part because i am sure 9 other people besides myself would realy like to be your new best friends lol
Old 07-27-2016, 12:52 AM
Themonty73 Themonty73 is offline
Themonty73 is on a distinguished road
Wow, this is amazing work, keep it up it looks fabulous, mail I but one of those friends that gets a completed version grader PLEASE
Old 07-27-2016, 08:32 AM
Cooper's Avatar
Cooper Cooper is offline
I have always wanted to make a model as close to scale as possible. I'm more oriented towards the mechanical workings and trying to relate that to our scale versions. I know you have a tremendous amount of hidden work, set up, jigs, precision measurements, ect,,,,, but this is really paying off!! Very nice!! An inspiration for me when I think it can't be scaled down.
Looks really really good Stefan !!
Old 07-29-2016, 08:52 AM
Klebefix Klebefix is offline
Klebefix is on a distinguished road
Nice work
Old 07-29-2016, 10:51 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Outstanding work!!! What are the extra 2 holes in the covers that you just made for? Could they be for jack bolts to remove the covers with? Just a guess!!!
LYNN
Old 07-31-2016, 05:17 PM
Thanks very much guys. Yes, Lynn, you are right. Those covers sits quite tightly. The specification says "blade down force capability 11 058 kg (24,457 lb). Don´t think the screws alone would cope with that for a long time (guess the real screws are 1/2 inch dia.). I use M1.6 (about 1/16 ") in the model.
Stefan
Tags
1:8, grader, volvo
