Old 06-15-2016, 10:10 PM
Cat966c Cat966c is offline
Cat966c is on a distinguished road
Default Re: Final checklist?
Originally Posted by cosworth34677 View Post
ya as for drive you should see if you can find a rock crawler for a drive train. that way all of your gear box axles and drive shafts are there for you and its easyer to get the speed and power you want out of it. or do like i did.
drive train=
1. a rc4wd r2 tranny
2. 2 single out put tamiya axles for semi trucks
3. 4 traxxas metal u joints and a set of drive shafts
4. 65t crawler motor .
6. castle creations sidewinder v2 esc.
radio/ power =
1.tatci ttx650 6 channel radio
2. tatic tx55 servo(steering)
3.castel creation bec.
hydrauics=
1.magom hrc mini pump with motor.
2. 2 bags of magom hrc 3mm hose
3. 2 robart 3/8 x2.1/2 in cyclinders
4 1 5robart 5/8 x 2" cyclinder
5. 2way valve set magom hrc
6. one duritracs brushed forward only esc ( for pump motor)
battery=
1. 5000 mil 2s lipo
2. 1 radio shack rechargable 9v (lights)
lights/wire =
traxxis led replacement leds
bag of deans wet noodle wire
deans plugs
lhws heat shink
good thin solder
60w soldering iron
thats my basic setup
now tires wheel and the rest is up to you, do the research. you'll get it worked out.
Can I sub my 55t and matching esc instead? Cause I already got it
Also: I'm using my own axles and drive shafts instead, but I need a gearbox, and was thinking of using a rock crawler box? What's the power transfer from the motor?
Thanks (:
